Interesting destination-pattern regex puzzle
Hi Experts,
I am trying to write a single regular expression for the destination-pattern command to match all 4 digit numbers except 41XX and 42XX ?
Can you pelase help me?
Bala.
Funny.  Sorry, I just assumed you were concerned with the 4xxx range.  Anyway, for this you will need two dial-peers.
To match: 1000-4099 and 4300-9999
One dial-peer destination pattern: 4[0,3-9]..
The other dial-peer destination pattern: ^0^4...  (which means that the first digit can't be a 0 or a 4)
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
5 Replies 5
William Bell
You could use:
destination-pattern 4[0,3-9]..
See this link for more information and ideas on how you can use wildcards with destination patterns:
http://www.cisco.com/en/US/docs/ios/voice/dialpeer/configuration/guide/vd_dp_feat_cfg_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1067070
HTH.
Bill
Please remember to rate helpful posts.
Hi Bill,
Thanks a lot for your reply and the link.
destination-pattern 4[0,3-9] will match only numbers in the raneg 40XX and 43XX-49XXX.
I ws looking for a single destination pattern that will match all 4 digit extensions except 41xx and 42xx (all numbers in the range 1000-4099 and 4300-9999).
Any ideas on constructing the desired range using a single reg-ex?
Bala.
HTH.
Bill
Perfect Answer!!!
Thanks a lot, Bill !!!
Cheers,
Bala.
No problem.  Glad to be of assistance.
