International calls are not working over sip trunk
Syed
Level 3
Level 3
Dear All,
Due to some reasons we have requested to our ISP to block all international calling for a couple days.
Now international dialing is restored by ISP and confirmed, but we are unable to make any international call and I am receiving the below error from ISP. Any help would appreciated.
*Feb 8 07:53:24.477: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 10.196.188.150:5060;branch=z9hG4bK7D8C951A62
Record-Route: <sip:10.209.4.58:5060;transport=udp;lr>
Call-ID: DD638212-CD6F11E5-AD018D8C-687F9E3D@10.196.188.150
From: <sip:2729001@10.196.188.150>;tag=B9382E70-620
To: <sip:00919900990490@10.209.4.58>;tag=sbc0806hk3ccsih
CSeq: 101 INVITE
Reason: Q.850;cause=21;text="call rejected"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
Thank you
2 Accepted Solutions
Vivek Batra
If calling and called number in INVITE message is in accordance to your provider and still you are getting 403 Forbidden, you probably need to check with your provider.
- Vivek
Ok, please let us know once you have any inputs from ISP.
- Vivek
6 Replies 6
Vivek Batra
- Vivek
Thank you Vivek for your help.
I have informed the same to ISP at the earliest.
- Vivek
Sure, I shall keep you posted.
Hello Vivek,
Issue is fixed now. The problem was on telco side and they activated international calling.
Thanks for updating us back.
