International Dial Plan
mjacob
Hi - I've been struggling with CM 7.1 and establishing an international dial plan.  I've successfully created inter and intrasite route patterns.  And tried countless digit maniupulations and pre-at, or pre-dot selections.  Everything I try for an international call routes me to the Operator or Reorder.
Any thoughts?  Thx, Marcia
Jaime Valencia
You would need to explain what you have tried and has failed
The simplest way is just 9.011! and discard predot
Do you know exactly what telco is expecting???
011+number?
number but tagged as international without 011?
If you don't know what they're expecting, call them to find out and configure accordingly
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
