This is more a general design question , as I'm struggling with finding documentation on whether this should work.
I have IM&P ( Cluster 1) 10.5 to Lync 2010 Intradomain federated.Works fine using same domain e.g companyname.co.uk
I have IM&P (Cluster 2) 10.5 Interclustered to IM&P10.5 (Cluster 1). Works fine using the same domain e.g companyname.co.uk
Question is should I be able to communicate from Cluster 2 to the Lync 2010 via cluster 1.I have tested it and it doesn't work, however the question is should it?
