IP Communicator 8.6.2.0 - Need Protocol and Port Range (AT&T U-Verse Issue)
barbara.bryan1
I need to do port forwarding on my AT&T U-verse router in order to get Cisco IP Communicator 8.6.2.0 to work properly.  I need the Cisco IP Communicator Protocol (TCP or UDP) and Port (or Range) in order to do this.  Anyone know?  Thanks in advance.  Barbara
nalonsopresidio
Ports Used by Cisco IP Communicator
IP Communicator is the same as normal IP phone, so it uses these ports:
  • TFTP (UDP 69)—In order to obtain phone configuration and software
  • SCCP (TCP 2000)—For skinny (SCCP) signaling
  • HTTP (TCP 80)—In order to access IP Phone services
  • RTP (UDP 16384-32768)—For audio
nalonsopresidio
Thank you so much.  You provided the right solution and it worked!
