IP Communicator Android
clark white
Level 2
Level 2
Hi ,
Do cisco has a ip communicator for Android phones ??? That can be connected through the VPN in coporate Network.
I Hope the answer for above query is Cisco mobile APP for smart phones (Jabber ), I can install in Android and through VPN connection i can connect corporate CUCM and make internal calls and Instant messaging ,etc etc.
Correct, there is no CIPC for anything other than Windows.  For Windows, Macs, iPhone, and Android, Cisco Jabber takes the place of CIPC.
8 Replies 8
Joseph Martini
Cisco Jabber! Here's a link to more information http://www.cisco.com/en/US/products/ps11678/index.html
Do i am correct, there is no CIPC for Android, Cisco Jabber is doing the same job for IP communicator on ANdroid Phones
Please correct me.
which Cisco VPN client can be used for android smart phones,
Anyconnect VPN is for SSL vpn not for IPSEC VPN
Sorry I didn't see where you speified the requirement of IPSEC instead of SSL.
Dear Joe,
Sorry i didnt specify, But is it there???
