11-29-2011 01:06 PM - edited 03-16-2019 08:17 AM
Hi all,
I recieved a new Phone on our company, the phone is a Cisco IP Phone 6921, I use the Ethernet Cable to connect it to the switch, and the phone do not power up with any message, my question here, can this switch:
Show ver. |
Cisco Internetwork Operating System Software IOS (tm) C3500xl Software (C3500xl-C3H2S-M), Version 12.0(5)WC5, RELEASE SOFTWARE (fc1) Copyright (c) 1986-2002 by cisco Systems, Inc. Compiled Tue 28-May-02 11:41 by devgoyal Image text-base: 0x00003000, data-base: 0x0034A3C8 ROM: Bootstrap program is C3500xl boot loader PAB01-TyRVITI-A-sw3524-01 uptime is 3 weeks, 2 days, 20 hours, 42 minutes System returned to ROM by power-on System image file is "flash:c3500xl-c3h2s-mz.120-5.WC5.bin" cisco WS-C3524-PWR-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes of memory. Processor board ID FAA0502M0W0, with hardware revision 0x00 Last reset from power-on Processor is running Enterprise Edition Software Cluster command switch capable Cluster member switch capable 24 FastEthernet/IEEE 802.3 interface(s) 2 Gigabit Ethernet/IEEE 802.3 interface(s) 32K bytes of flash-simulated non-volatile configuration memory. Power supply part number: 34-0968-01 Power supply serial number: DAB042810Z3 Model revision number: A0 Motherboard revision number: B0 Model number: WS-C3524-PWR-XL-EN Configuration register is 0xF |
Should work with my IP Phone 6921 Cisco?
I have done those troubleshooting here:
I enter the switch configuration, the device look as "not conected" and iether no CDP Protocol information.
¿Do you know what happen here?
Regards!
Solved! Go to Solution.
11-29-2011 01:38 PM
I dont think your 3524 is compatable with a 69xx phone
3534 is really old and uses a Cisco propriety method for delivering POE but OK
with older 7940/60 type phones
69xx phones need POE as 802.3AF as delivered by newer 3750/3560 etc type switches
Alex
11-29-2011 01:38 PM
Alex
12-14-2011 07:16 AM
Thank youm u' where right, 6921 Phone's worked on a 3560 Switch and never on a 3524 Switch, U' can't force that swtich to work with those phones. I had to buy a power cube.
Regards.
http://www.velocityreviews.com/forums/t232567-hack-a-cisco-switch-to-be-802-3af.html
06-27-2012 02:56 AM
How about in 3550 inline power switch? I get the 6901 blinking but no luck of getting its IVR prompts. Does the 3550 doesnt support also the 69XX Phones. Many thanks.
