IP PHONE 7941 SERIES
I have problems with an IP PHONE 7641. All buttons are turned on, there is no dialtone and the screen is off. I tried to change it to other port but won't work.
Hi Melissa.
Which CUCM/CUCME version ar you running?
Have you tried factory reset?
If you need the procedure, here is the link
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-ip-phone-7900-series/15254-7960-default.html
Carlo
Please rate all helpful posts "The more you help the more you learn"
I did it but won't work.
Hi Melissa.
Which version of CUCM are you running.
You should also make sure that ip phone is correctly receiving ip address and 150 option.
Please let me know
Carlo
