IP Phone 9971 Authentication MS-CHAP v2 support
cristian.munoz
Level 4
Level 4
Hi Guys
I´m trying to connect the IP Phone 9971 using the wifi, but not works. The authentication protocol is MS-CHAP v2.
My question is the ip phone 9971 supported the MS-CHAP v2 protocol?
TIA
Cristian
Dear Venkatesh.
I read this document before but i can´t find some of configuring about MS-CHAP v2
TIA
Cristian
Hello
Someone has made a wifi connection using authentication protocol EAP-MSCHAP V2 ??
TIA
Cristian
Hi Guys
Yesterday I continued checking the issue and I have the messages of IP Phone events:
1.- Analyzing the current configuration of WLAN
2.- Error association of WLAN AP
3.- WLAN can not connect to the domain controller
4.- Authentication Error WLAN AP
I performed a test using my notebook to access the same WLAN network (same SSID, user and password) and works fine.
In the notebook, the WLAN properties are:
- Security type: WPA2 Enterprise
- Encryption type: AES
- Authentication method: EAP-MSCHAP v2
Adding, the IP Phone Firmware is : sip9971.9.3-2-10 and the WLAN Controller is using RADIUS for authenticaction.
Any idea? What more test do I do?
TIA
Cristian
