I need to setup 5 phones which should ring at same time if first phone is busy then it should go to second, followed by third, forth and fifth then to voice mail Let me know if it can be done Call Manager version 9.0
Hello, I need your advise. I have problem with conferencing for any user using Cisco Ip phone and connecting over VPN. So whenever anybody from the office tried to conference with these remote users , the call dropped for...
I seem to be having an issue with inbound calls from my SIP ITSP (voip.ms). Calls are reaching my voice gateway (CME Version 8.6) are failing with an error SIP/2.0 400 Bad Request - 'Invalid Host'. I am getting the SIP Invite message but respond with...
Hi,I got this error last few days:Pilot3Peci.c:152:Pilot3ReadCPUTempViaPECI:DROPPING PECI READING CPU Number:1 prev:-4423 curr:-3782 Only thing I found was this bug https://tools.cisco.com/bugsearch/bug/CSCue41214 , but it mentions different error. ...
I have an 8861 phone already working. I also see the 8851 model show up on the Device Defaults page as a model that's known and has a default firmware listed. However, I don't see anything at all on the Device Defaults page for the 8811. There's ...
Hi I want to setup CCIE Voip lab. The below is list of devices. Can you give some suggestion on it? Thank you - R1: 2821 Router 256D/64F with IOS 15.1 + 2 Serial Ports + 2 Gigabit Ethernet Ports- R2: 2811 Router 256D/64F with IOS 15.1 + 1 Serial P...
Hello Friends, Requesting someone to explain what is meant by AXL Serivce. Like what components is used on it or what is it doing. I have CUCM and UCCX merged with this. So what it does. Can someone explain in leyman term. Thanks. Sanjay.
Hi Guys, I am trying to install install Cisco MediaSense Server on VM ware for my lab, But installation is getting failed with the below error. Can someone please advice what this error exactly means. Given 2GB RAM and 80GB HD for installation. Erro...
I am trying to setup a Cisco IP Phone 7960 series phone with my small business Optimum internet and need assistance and a guide to setting up the phone. When I attempt to put the ethernet cord connected to my Optimum router into the back of the IP p...
Hi , We have a VG350 connecting to out CUCM network. Can someone explain what type of licenses we need? We do plan to have 5 FXO ports configured on the VG350. Thanks G
A little insight into the company first I guess. I have a client who has approximately 40 locations. Most of the sites use site-to-site VPN tunnels for communication purposes. 2 sites have point to point links with metro e to the corporate locatio...
Hi All, Please let me know what is the recommendation to put VG for Cisco Unified Communication Implementaion! Is it in front of Firewall or behind the firewall? Thanks in advance.
When calling into Unity , I need to be able to press* to access a different mail box other then the one Im calling from- It doesnt work. I didnt think I had to configure this- any help? thanks
Hello, my customer wants to use Unity AA feature as an IVR prior routing calls to Call Center. In the automated attendant, one of the choice of caller need to route the call to a PSTN number. How to achieve this? 1. route to an internal dummy number...
Hello all I'm looking to find a solution for users they have a shared line on the phone and want this line not ringing, only the flash light should alert an incoming call. I know that I'm able to configure this as administrator, but we want that the ...
Subject | Author | Posted |
06-19-2025 08:23 PM | ||
06-17-2025 07:43 AM | ||
06-17-2025 06:11 AM | ||
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
