IP Phone Auto Shut down
madhusudhanam
Hi Friends,
We would like to auto shutdown the IP Phone after desired time,by doing this i would like to show the ROI to the customer, can any one know the solution to enable the auto shutdown for IP Phones in CUCM or if any work around method to achieve the requirement.
Thanks in advance.
M.Madhusudhana Rao
My idea is to switch off the poe via a snmp command,
therefore the phone will be stopped if you have a pc attached to the phone it is isolated.
My two cents.
Philippe
Hi Philippe,
I think, the port which is conecting to PC wont get the LAN connection once the IP phone gets powered off.
M.Madhusudhana Rao
CUCM has some options for this, have you looked at them??
This field allows the user to specify the days that the display is to  remain off by default.  Typically this would be Saturday and Sunday for  US corporate customers.  Saturday and Sunday should be the default.    The list contains all of the days of the week.  To turn off display on  Saturday and Sunday the User would hold down Control and select Saturday  and Sunday.
This field indicates the time of day the display is to automatically  turn itself on for days listed in the off schedule. The value should be  in a 24 hour format. Where 0:00 is the beginning of the day and 23:59 is  the end of the day. Leaving this field blank will activate the display  at the default time of the day (e.g. - "7:30"). To set the display to  turn on at 7:00AM the user would enter "07:00" without the quotes. To  have the display to turn on at 2:00PM enter "14:00" without the quotes.
   Default:                  07:30
   Maximum length:                5
This field indicates the amount of time the display is to be active  for when it is turned on by the programmed schedule.  No value indicates  the end of the day.  Maximum value is 24 hours.  This value is in free  form hours and minutes.  "1:30" would activate the display for one hour  and 30 minutes.
   Default:                  10:30
   Maximum length:                5
This field indicates how long to wait before the display is turned  off when it was turned on by user activity.  This inactivity timer will  continually reset itself during user activity.  Leaving this field blank  will make the phone use a pre-determined default value of one hour.   Maximum value is 24 hours.  This value can be in free form hours and  minutes.  "1:30" would turn off the display after one hour and 30  minutes of inactivity
   Default:                  01:00
   Maximum length:                5
To enable the Power Save Plus feature, select the day(s) that you  want the phone to power off on schedule. You can select multiple days by  pressing and holding the Control key while clicking on the days that  you want Power Save Plus to operate.                     The default is disabled (no days selected).                     In Power Save Plus mode, enough power is maintained to illuminate  one key. All other functions of the phone are turned off in Power Save  Plus mode. Power Save Plus mode turns off the phone for the time period  specified in the Phone On Time and Phone Off Time fields. This time  period is usually outside of your organization's regular operating  hours.                     The illuminated key allows a user to press it to restore full power  to the phone. After pressing the illuminated key, the phone power-cycles  and reregisters with Unified CM before it becomes fully operational.  Power Save Plus is disabled by default. When you select day(s) in this  field, the following notice displays to indicate e911 concerns. By  enabling Power Save Plus, you are agreeing to the terms specified in  this Notice.                     Notice: WHILE POWER SAVE PLUS MODE (THE "MODE") IS IN EFFECT,  ENDPOINTS CONFIGURED FOR THE MODE ARE DISABLED FOR EMERGENCY CALLING AND  FROM RECEIVING INBOUND CALLS. BY SELECTING THIS MODE, YOU AGREE TO THE  FOLLOWING: (I) YOU ARE TAKING FULL RESPONSIBILITY FOR PROVIDING  ALTERNATE METHODS FOR EMERGENCY CALLING AND RECEIVING CALLS WHILE THE  MODE IS IN EFFECT; (II) CISCO HAS NO LIABILITY IN CONNECTION WITH YOUR  SELECTION OF THE MODE AND ALL LIABILITY IN CONNECTION WITH ENABLING THE  MODE IS YOUR RESPONSIBILITY; AND (III) YOU WILL FULLY INFORM USERS OF  THE EFFECTS OF THE MODE ON CALLS, CALLING AND OTHERWISE.
This field determines the time that the phone turns on automatically  on the days that are selected in the Enable Power Save Plus list box.                     Enter the time in 24 hour format, where 00:00 represents midnight.  For example, to automatically turn the phone on at 7:00 a.m., (0700),  enter 07:00. To turn the phone on at 2:00 p.m. (1400), enter 14:00.                     If this field is blank, the phone automatically turns on at 00:00.  The default is blank.
   Default:                  00:00
   Maximum length:                5
This field determines the time of day that the phone will turn itself  off on the days that are selected in the Enable Power Save Plus list  box. Enter the time in the following format hours:minutes. If this field  is blank, the phone automatically turns off at midnight (00:00). The  default is blank.                     Note: If Phone On Time is blank (or 00:00) and Phone Off Time is  blank (or 24:00), the phone will remain on continuously, effectively  disabling the Power Save Plus feature unless you allow EnergyWise to  send overrides.
   Default:                  24:00
   Maximum length:                5
This field represents the number of minutes that the device must be  idle before the device will request the power sourcing equipment (PSE)  to power down the device. The value in this field takes effect:                     - When the device was in Power Save Plus mode as scheduled and was  taken out of Power Save Plus mode because the phone user pressed the  select key                     - When the phone is repowered by the attached switch                     - When the Phone Off Time is met but the phone is in use The unit is  minutes. The default is 60. The range is 20 to 1440.
   This is a required field.
   Default:                  60
   Minimum:                  20
   Maximum:                  1440
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
