IP Phone Avialablity report
cisco.madhab
Hii all,
is it possible to send the register & unregister phones list which we can see from CCM device list, to NMS?
pls Reply asap.
Thanks & Regards
Madhab
8 Replies 8
virverma
Level 4
Level 4
there is no direct way to see
that information. You can, however, create a XML service who asks CM
about the phone status via AXL.
hi virverma ,
Thanks for reply..
Please tell me details procedure for that.
Thanks & Regards
Madhab
Hi virverma,
thank you very much for this link.
its very much help full.
Now I want to know How can I access CLI mode of Linux based CUCM box.
is it possible?
Thanks & Regards
Madhab
hi virverma,
When I am going to configure the SNMP notification Destination, it's asking a comunity string parameter and I already configured a comunity string for existing server, but its not taking in that parameter.
What's the mistek there?
thanks & Regards
Madhab
You can connect to your cucm cli box by doing ssh, I am assuming that it ccm 5.X or 6.X or 7.X
check the link,
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=CISCO-CCM-CAPABILITY
make sure you restart all service,
there is a separate link for configuration of linux based cucm
Hi virverma
Thank you very much again.
I am going through this document and try to resolve the issue. If any help will be required, I wiil get back to you
Thanks & Regards
Madhab
sure, it will be a learning experience for me as well
