IP phone keeps giving busy tone
akramalsheikh87
hello,
we're facing an issue with one of our branch offices. the issue is that two phones there (8851 model) keeps giving busy tones when tryin to call them. also when they pick up the line and try to press any number it gives busy tone directly. both phones are registered fine. they were working before and this suddenly happened. i changed the codec, tried reset factory with no hope.
below CCSIP log when i try to dial the number 302 from my extension 2773
Mar 14 09:28:22.895: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:302@192.168.1.100:5060 SIP/2.0
Via: SIP/2.0/TCP 172.24.128.102:5060;branch=z9hG4bK133ef545abf13b
From: "Akram Al Sheikh" <sip:2773@172.24.128.102>;tag=13693128~e6e28775-6cc7-4b93-b983-5ce737e574da-38768118
To: <sip:302@192.168.1.100>
Date: Tue, 14 Mar 2017 09:28:22 GMT
Call-ID: 8fd9c480-8c71b7b6-5e72a-668018ac@172.24.128.102
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM11.0
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:172.24.128.102:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Session-ID: 9df18ec6eb7797afd0cd89aa13693107;remote=00000000000000000000000000000000
Cisco-Guid: 2413413504-0000065536-0000064343-1719670956
Session-Expires: 1800
P-Asserted-Identity: "Akram Al Sheikh" <sip:2773@172.24.128.102>
Remote-Party-ID: "Akram Al Sheikh" <sip:2773@172.24.128.102>;party=calling;screen=yes;privacy=off
Contact: <sip:2773@172.24.128.102:5060;transport=tcp>
Max-Forwards: 69
Content-Length: 0
Mar 14 09:28:22.903: //3787/8FD9C4800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 14 Mar 2017 12:28:22 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.6.3.M1
Session-ID: 00000000000000000000000000000000;remote=9df18ec6eb7797afd0cd89aa13693107
Content-Length: 0
Sent:
SIP/2.0 486 Busy here
To: <sip:302@192.168.1.100>;tag=1E5FCA7C-1C94
CSeq: 101 INVITE
Reason: Q.850;cause=17
Session-ID: 9df18ec6eb7797afd0cd89aa13693107;remote=d9096ab5ceee5195b83386a371eeb772
Content-Length: 0
Mar 14 09:28:23.079: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:302@192.168.1.100:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
voice register dn 4
number 302
name Ferhan Ozduzenciler
shared-line max-calls 4
label Ferhan Ozduzenciler
voice register pool 4
busy-trigger-per-button 2
id mac 00CC.FC40.C71C
type 8851
number 1 dn 4
dtmf-relay rtp-nte sip-kpml
voice-class codec 1
no vad
Debug Indicates that the called party is unable to accept another call because the user busy condition has been encountered. This cause value can be generated by the called user or by the network
As per the config you have configured busy-trigger-per-button 2, change it to 4 and see if that makes a difference or not.
Abhay
Rate all helpful posts !!!
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
