IP Phone looking not finding CCUM
martynch1
Well this is an interesting one, I have a vmware CCUM v6 installed on  192.168.3.202 and I can browse to the web interface OK.
I have a  DHCP server set-up on my ACS server which is 192.168.3.201 which is  giving out both IP's for the Phones and my PC so that is working ok.
I  have set-up option 150 to point to my pc's TFTP server 192.168.3.150 so  I can see TFTP requests coming which is happening.
Problem is  that when I check on the IP phone under Device configuration Callmanager  configuration, call manager 1 is pointing to my tftp server of  192.168.3.150 instead of 192.168.3.202
Does anybody have any idea  why its picked that address up instead of the CCUM address?
Cheers
Martyn
dcarhart
What was it the ip info on the ccm or the switch
Dave Carhart
On Apr 30, 2010, at 8:33 AM, "martynch1"
12 Replies 12
dcarhart
hi I have a couple of questions.
Why are you using 192.168.3.150 for your TFTP server is this another Call Manager?
I would just turn the TFTP service on  you call manager 192.168.3.202 and then restart your phone
by giving it the DHCP  150 option you are basically telling the phone your call manager is the 3.150
Thanks for the reply...
No 3.150 is no another call manager, I will turn on the tftp withing the call manager.
Do I still need the option 150 on the DHCP server?
Thanks again
Martyn
Yes you will still need the option 150 in your scope.
Dave
Looking back over the options I have tried that was one of them, I thought I had it wrong because my phone does not register.
I have the MAC address in call manager but it does not register, I dont get anything from the phone status apart from TFTP Timeout SEPconf.xml can not be found, the phone has the correct 10. ip address and is in the correct voice VLAN which is 3.
Any ideas what I should be checking to help me fault find?
Martyn
OK from the call manager I try and ping 10.50.50.1 I get the following: -
PING 10.50.50.1 (10.50.50.1) 56(84) bytes of data.
--- 10.50.50.1 ping statistics ---
1 packets transmitted, 0 received, 100% packet loss, time 0ms
From my Switch I get: -
Switch#ping 10.50.50.1
Sending 5, 100-byte ICMP Echos to 10.50.50.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Switch#
Here is my switch config: -
interface FastEthernet0/15
description *****Call Manager*****
switchport mode access
spanning-tree portfast
interface FastEthernet0/33
description *****Martyn's IP Phone*****
switchport voice vlan 3
interface Vlan1
description *****Data*****
ip address 192.168.3.250 255.255.255.0
ip helper-address 192.168.3.201
interface Vlan3
description *****Voice*****
ip address 10.50.50.250 255.255.255.0
Hope you can help
Martyn
Okay
I'm just going to think this one out loud so please bare with me
So I can ping the phone from the switch but not from the ccm
I first would double check the ccm's ip config to make sure I have the
subnet mask and gateway correct
Also double check the dhcp scopes to make sure your giving the right
gateway and subnet
Then if that is correct I would ping from the switch to the ccm using
the extended ping and the ips of the different vlans as the source
Based on what you said in the last email I'm expecting it to fail when
you put the ip of vlan 3 as your source.
If it fails you have a routing issue on your switch with the vlans and
You need to make sure you have layer 3 routing enabled on the switch
just make sure you have ip routing enabled. On the switch this will
correct that layer 3 issue
Dave Carhart
On Apr 29, 2010, at 5:22 PM, "martynch1"
Also on vlan 1 you don't need the helper address on the vlan the dchp
server is in that vlan so you don't have to worry about the broad
casts not making it to the users
Dave Carhart
Thanks Dave... Corrected
interface Vlan1
The post before that.
192.168.3.202
255.255.255.0
192.168.3.254
gateway and subnet
PC Pool
192.168.3.150 - 192.168.3.250
Router 192.168.3.254
Phone Pool
10.50.50.1 - 10.50.50.50
Router 10.50.50.1250
Option 150 192.168.3.202
Yes that fails as you thought
Here is my full config, wll not full I'm not listing out all the SwitchPorts
no aaa new-model
vtp domain VTP1
vtp mode transparent
ip subnet-zero
ip routing
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 3
name voice-vlan
interface Vlan1
interface Vlan3
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.3.254
ip http server
control-plane
My LAN looks connects like the following: -
Cable Modem > ASA (192.168.3.254) > Switch (192.168.3.250) > LAN
Thanks for your continued support.
dcarhart
Dave Carhart
No, Not working yet, I was just responding to your last post with regards to the IP Helper... I hit reply after instead of continuing the post.
Hi Dave, CM default gateway address pointed to my ASA, once I changed
it to the Switch all worked after that.
Cheers Dave for all your help.
Martyn
That's great I'm glad it was something simple trying to figure out the
switch end can be a nightmare sometimes
Dave Carhart
On May 3, 2010, at 11:05 AM, "martynch1"
