ip phone to ip phone Busy Tone.
rapperjky
Hi all...!
nice to see you.
hmm...
i have one question.
we use CUCM 7.1.2
calling from ip phone(A) to ip phone(B) (Local)
If Phone B not answer(don't pick up) continue Ringing then, we will listen busy tone.
my customer want to listen other ment ex) music or anything.
(we didnt use voice mail.)
we can adjust this?
somebody help me~
thank you all.
islam.irshaid
You can remove the busy by change the " " to be 300
you can change it globally via Service Parameter Configuration
or under the directory number
hi islam
thank you your answer.
forwarding no answer is not solution.
that point is play ment.
ex) im so sorry im very busy or blublu~
CUCM upload WAV file and we can use Instead of busy tone.
ah ,,, you sould use Unity or TCL script on gateways.
