IP Phones not registering to CUCM on VMWARE (VMWare Fusion on MACBook Pro)
GenericTFTP1
Hello Everyone,
I am new to the forum. I am having the following issue when running a voice lab at home
false
1: Running 8.6 CUCM on VMWare Fusion on MacBook Pro.( I am wondering if there are any related issues with running CUCM on MAC)
2: Router is able to ping the CUCM 192.168.1.117
3: IP Phone gets its IP Address from DHCP pool on Router 10.1.1.2
4: CUCM is unable to ping the Phone
I was wondering if anyone has been through a same situation and could help me out with the issue.
Any help would be greatly appreciated.
false
GenericTFTP1
please see attached for the lab diagram
Are you able to ping any IP address in phone subnet from MAC. Please check which network type is used and try changing to see if that helps as we first need to establish connectivity between the two subnets.
kb.vmware.com/selfservice/search.do?cmd=displayKC&docType=kc&docTypeID=DT_KB_1_1&externalId=1022264
Rajan
Pls check the below link to get more info on this and select the right option.
https://communities.vmware.com/docs/DOC-2527
Rajan
Please rate all useful posts
