IP Pone 6921 - 1 hour early CUCM 10x
Reigota95
Have a CUCM version at 10x, I noticed that one day they anticipated 1 hour. But that only happened with the models 6921 and has some that continue with the correct time.
What should be done?
Active Load ID SCCP69xx.9-4-1-3SR1
My NTP is synchronized.
5 Replies 5
Can you make sure that your phones are matching the load configured in CUCM device defaults for 6921?
What are these standards? Could you tell me the way?
I did not quite understand the question
CUCM Administration >> Device >> Device Settings >> Device Defaults
Deepak
Thx Deepak.
Reigota, as mentioned by Deepak, from this path check what is the load configured for 6921 then compare it with your active load.
I have scenarios where phones fail to down the configured load and that is reflecting on the clock. Once you perform factory reset the phones will get the new load and the clock with be fixed
Hi Experts,
A week after daylight saving time ends, the 6921 devices back to the correct time.
