IP Telephony and Phones CUCM 7.1.5
mtandrew78
I am having issues with locating voicemail to email notification in this old version of CUCM - 7.1.5.  Any suggestions on where it would be at?
Jaime Valencia
Not on CUCM, as that is a voice mail feature.
On that version you could have either CUC or Unity.
java
if this helps, please rate
We have Cisco Unity 7.0 Build 7.0(2). I just don't see the option for SMTP option or email delivery.
On Unity you forcefully needed to use Exchange or Domino as the message store, and via that integration you would get the voicemail to email integration as you do in UM with CUC.
If you mean you want something like the accept and relay feature from CUC, that does not exist in Unity.
That version is long EOS/EOL and I don't even believe the documentation for the product is available anymore.
java
