IP Telephony configuration
engineer_msu
Hi All,
I need to configure IP Telephony between two sites, on both the sites I have Cisco Voice Enabled routers,
Main Site Router - 3660
Remote Site - 2600
Please provide me complete details how to configure IP Telephony between these sites. I am very much new to IP Telephony.
paolo bevilacqua
Complete details without evening knowing anything about your installation ???
Seems like your desire is to get it working by cut&paste?
Perhaps you should engange a certified partner or reputable consultant to configure your systems properly and save yourself a lot of time and frustratition.
Criss Sawyer
hi,
you have to configure your both router as a CME (CallManger Express) otherwise you have to have a cisco CallManger server installed in your in enviroment, then you can add your both gateways and have them configured.
