IP Telephony with 802.1X EAP-TLS (LSC) to AAA Windows 2008 NPS
timohaas
We are having trouble to get the following configuration to work properly:
Have a CUCM 8.5 Cluster with different IP Phones (7965/7975/..) attached. Our Enterprise CA is based on Windows 2008 R2 Server, same Server acting as NPS / RADIUS Server. Access switches are 2960.
When we try to implement 802.1X we first did it with the switches and PC´s.. no problems.
Then we exported the certificates to the CUCM to have the CAPF install the LSC on the phones.
For Testing we installed a CSACS 5.2 - when using the ACS the phones complete the authorization and the port gets into the correct state so that the phone can register to CUCM.
Now we want the 2008 NPS to do all the work - but we do not get it running....
Anyone had the same situation?
No, but we have exactly the same problem here and it would be great to have a proper solution...
