IP2IP(CUBE) and transcoding
Borkes1985
Hi!
I have the CUBE router recieving h.323 calls from Provider, codec is g729. I need to configure IVR(vxml) support on this router on incoming calls, IVR uses g711alaw codec. How should I configure DSP resources for this task?
I have read about universal transcoding and here is my config:
voice-card 0
no dspfarm
dsp services dspfarm
voice service voip
application
service myclock flash:/100/100.vxml
sccp local FastEthernet0/0
sccp ccm XX.XX.XX.XX identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 10 register MTPXXV000
associate profile 20 register MTPXXVIII
keepalive retries 5
switchback method immediate
dspfarm profile 20 transcode universal
codec g711ulaw
codec g711alaw
codec ilbc
codec g723r63
codec g723r53
codec gsmamr-nb
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 2
associate application SCCP
dspfarm profile 10 transcode
codec g711ulaw
codec g711alaw
codec ilbc
codec g723r63
codec g723r53
codec gsmamr-nb
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 2
telephony-service
sdspfarm units 2
sdspfarm transcode sessions 30
sdspfarm tag 1 MTPXXVIII
sdspfarm tag 2 MTPXXV000
max-ephones 20
max-dn 20
ip source-address XX.XX.XX.XX port 2000
max-conferences 12 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Apr 06 2009 08:48:41
Dial-peers:
voice translation-rule 1
rule 1 /84955555555/ /999/
voice translation-profile 1
translate called 1
dial-peer voice 1 voip
description to_IVR
service myclock
destination-pattern 999
session target ipv4:62.117.78.213
incoming called-number 999
codec g711alaw
dial-peer voice 3 voip
description -=cellular=-
destination-pattern 89167396844
session target ipv4:212.48.128.217
dial-peer voice 2 voip
description incoming_peer
translation-profile incoming 1
incoming called-number 84955555555
PS:CUBE is a cisco 2811 with PVDM2-16.
IOS:c2800nm-advipservicesk9-mz.124-11.XW10.bin
Although DSP profiles are registered, but they are not beeing activated while calls ocure. The calling party hears fast busy.
Does 'show sccp' show them as registered?
And are you sure you're running into a codec problem (cause=47) and not some other problem causing fast busy?
-nick
vxml#sh sccp
SCCP Admin State: UP
Gateway IP Address: XX.XX.XX.XX, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: XX.XX.XX.XX, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
Trustpoint: N/A
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 62.117.78.213, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 10
Reported Max Streams: 12, Reported Max OOS Streams: 0
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: ilbc, Maximum Packetization Period: 60
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
sistefanov
I faced this transcoding issue and changing IOS to Version 12.4(15)T8 resolve it.
Original IOS version was 12.4.11 T3.
