IPSEC-TRUST Certificate missing from subscriber
phifdd4305
My UCS host crashed and when I brought it back up the CUCM .6.2.22044-1 subscriber DRF service began failing. I found that the ipsec-trust certificate is completely missing. Whats the process on getting that back? I have 2 other subscribers that have the cert with the same serial number as the one on the publisher. Any help would be appreciated since my backups are now failing.
Jaime Valencia
How did you bring that certificate back? DRS?
is the certificate actually missing from the OS admin?
java
if this helps, please rate
I didn't yet and yes is is completely gone
You need to restore that server from a DRS restore to get back all the certificates you had before.
java
