Is there a product compatibility matrix for PLM 11.5?
Nadav
Level 7
Level 7
Hi everyone,
I'm looking for a compatibility matrix for PLM 11.5. Specifically if it supports CUCM 11.0.1SU2.  I didn't find one in either the PLM wiki nor PLM documentation. Any chance you can refer me to a relevant document?
Thanks!
Jitender Bhandari
Hi Nadav,
PLM 11.5 Would support CUCM 9.X \ 10.X \ 11.X it is test in LAB and supported through TAC.
JB
Jitender Bhandari
Hi Nadav,
JB
Also see below
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/11_5_1/releasenotes/CPLM_BK_RBE149CB_00_plm-rn-1151/CPLM_BK_RBE149CB_00_plm-rn-1151_chapter_00.html
Product Interactions for Enterprise License Manager
The product interactions or product versions supported by Enterprise License Manager and Cisco Prime License Manager are shown below. For example, while Cisco Prime License Manager Release 10.x supports Cisco Unified Communications Manager and Cisco Unity Connection Release 10.x, a license definition update is required for Enterprise License Manager. License definition updates for Enterprise License Manager 9.x are applied by the installation of elm_LicenseDef_9_1_v1.cop.sgn (or the latest version) located at the Software Download Center under Prime License Manager Software Patches.
Table 1 Product Interactions Support Matrix
Product Instance Version Managed By Enterprise License Manager 9.1
Managed by Cisco Prime License Manager 10.x and 11.x
CUCM 9.1
Yes
Yes
CUC 9.1
Yes
Yes
CUCM 10.0(1) and later
Yes
W/ License Definition Updates
Yes
CUC 10.0(1) and later
Yes
Yes
CER 10.0(1) and later
No
Yes
JB
