Is there a "best practise" for Fax with ASA-187 on CUCME?
alig.norbert
Level 4
Level 4
Hi all,
I got some issues with incoming fax through an ATA-187 on CUCME 9.1.
Is there some best practise sheets or can someone spare a setup to check the settings, supported speed e.g.
Kind regards,
Norbert
Alig,
Try to change the FAX Protocol pass-through and try
Selvarathnam
