Is there an approved USB-to-3.5mm converter that can be used on a DX80 for mic & headset?
erich.vincent
We recently upgraded from EX90s to DX80s.  The problem we discovered is, with the EX90 we bought headset & mic's that used 3.5mm jacks.  Unfortunately, there are no 3.5mm ports on the DX80, only USB.  Is there a USB-to-3.5mm converter that can be used on a DX80?  I found a converter, but it comes with a driver disk and since there's probably no way to install that driver on a DX80, I'm afraid the converter won't work.https://www.startech.com/Cards-Adapters/Sound/USB-Audio/USB-20-to-Audio-Adapter~ICUSBAUDIO
George Sotiropoulos
Hello Erich,
I would strongly sugget to contact your Local Cisco Certified Partner (if not anyone specific, search here: https://locatr.cloudapps.cisco.com/WWChannels/LOCATR/openBasicSearch.do ) or even better your Cisco Account Manager, to check this internaly and get some feedback for such cases.
George
Hope the above helps,
gsotirop
