ISDN BRI outbound calls with trunk group
Support Albakom
Level 3
Level 3
hi,
we have an 2911 cisco router with 6 ISDN BRI ports.
I configured them as trunk group in round robin hunt scheme.
The I configured a outbound pots dial-peer. I start an outgoing call. Debug isdn q931 shows that the call is going to the first BRI Port.
If theres a TELCO connected the call will succeeded. But if the BRI port down, the call doesnt hop to next port of the six, which is connected. So the redundancy of BRI ports isnt available. Is ther a way to configure this? I want that the call goes to another BRI interface, if the choosen one is not active or busy.
heathrw
Level 4
Level 4
Try adding global command:
no dial-peer outbound status-check pots
