ISDN E1 - 2801 - 64 DSP - %Insufficient resources to create pri-group
nwkotze
OVR-LAN-V-GW1#sho inv
NAME: "chassis", DESCR: "2801 chassis"
PID: CISCO2801 , VID: VN/A, SN:
NAME: "VIC 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN:
NAME: "PVDM 0", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN:
S2S-OVR-LAN-V-GW1#
card type e1 0 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
controller E1 0/0/0
framing NO-CRC4
S2S-OVR-LAN-V-GW1(config-controller)#pri-group timeslots 1-31
% Not all config may be removed and may reappear after reactivating the logical-interface/sub-interfaces
%Insufficient resources to create pri-group - it has been removed
S2S-OVR-LAN-V-GW1#sho flash
-#- --length-- -----date/time------ path
1 27352008 Jul 10 2009 17:39:42 +01:00 c2801-spservicesk9-mz.124-25a.bin
36532224 bytes available (27353088 bytes used)
sho ver:
System image file is "flash:c2801-spservicesk9-mz.124-25a.bin"
Cisco 2801 (revision 5.0) with 352256K/40960K bytes of memory.
Processor board ID FHK084711TB
2 FastEthernet interfaces
2 Channelized E1/PRI ports
4 DSPs, 64 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62592K bytes of ATA CompactFlash
20 Replies 20
nwkotze
Errors
1. Two or more items are incompatible. Selected or default-included item: [S280IPB-12415T] is incompatible with: [ PVDM2-64 ]. Please change one or more items.
To correct this error REPLACE the S280IPB-12415T from the following options
(2801 SOFTWARE:S280IPB:S280IPB-12415T)
S280AESK9-Advanced Enterprise Services
S280AISK9-Advanced IP Services
S280ES-Enterprise Services
S280ESK9-Enterprise Services w/Security
S280IPV-IP Voice
S280IPVK9-IP Voice w/Security
S280SPSK9-SP Services
OR
To correct this error REMOVE from the following options
PVDM2-64
64-Channel Packet Voice/Fax DSP Module
(2801 PVDM 0:PVDM2-64)
12.4.15T IP Base software is not "incompatible" with the PVDM2-64 DSP module. This code does not have any voice features, so the DSP and the voice cards won't be recognised and you will not be able to configure anything voice related.
Assuming you do have the correct version of code, does this have any relevance to moving the E1 card out of slot 0 into the recommended slot so PRI can be configured?
controller E1 0/3/0
controller E1 0/3/1
ip tcp synwait-time 10
S2S-OVR-LAN-V-GW1#config t
Enter configuration commands, one per line. End with CNTL/Z.
S2S-OVR-LAN-V-GW1(config)#controller E1 0/3/0
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 3
*Jul 16 10:04:26.515: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(1), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(2), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(3), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(4), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(5), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(6), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(7), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(8), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(9), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(10), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(11), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(12), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(13), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(14), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(15), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(17), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(18), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(19), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(20), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(21), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(22), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(23), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(24), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(25), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(26), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(27), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(28), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(29), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(30), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(31), changed state to up
S2S-OVR-LAN-V-GW1(config-controller)#end
S2S-OVR-LAN-V-GW1#wr
Building configuration...
Compressed configuration from 4929 bytes to 2935 bytes
*Jul 16 10:04:46.975: %SYS-5-CONFIG_I: Configured from console by console[OK]
S2S-OVR-LAN-V-GW1#dir
Directory of flash:/
1 -rw- 33034640 Jul 16 2009 11:47:00 +01:00 c2801-ipvoice-mz.124-15.T9.bin
63877120 bytes total (30838784 bytes free)
S2S-OVR-LAN-V-GW1#
So ... it's all OK now ?
Yes, I got it working!!
angel.gino
I had the same problem. It moved vwic to slot 0 and it worked.
Thanks for the solution.
