ISR 4331 Voice Gateway IOS
ragavicisco
Hi All,
We are about to configure a new ISR 4331 router as voice gateway. It has in-built IOS software - Cisco IOS XE Software, Version 03.16.04b.S. Is it good to proceed with voice configurations on same IOS or do we have to download any other IOS software?
And also it is showing ROMMON mode. Please help us on how to remove that.
#show version
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software arelicensed under the GNU General Public License ("GPL") Version 2.0. Thesoftware code licensed under GPL Version 2.0 is free software that comeswith ABSOLUTELY NO WARRANTY. You can redistribute and/or modify suchGPL code under the terms of GPL Version 2.0. For more details, see thedocumentation or "License Notice" file accompanying the IOS-XE software,or the applicable URL provided on the flyer accompanying the IOS-XEsoftware.
ROM: IOS-XE ROMMON
TRU-THN-GW uptime is 15 weeks, 1 day, 21 hours, 20 minutes
Uptime for this control processor is 15 weeks, 1 day, 21 hours, 21 minutes
System returned to ROM by reload
System restarted at 15:47:47 IST Tue Oct 24 2017
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: Reload Command
cisco ISR4331/K9 (1RU) processor with 3696789K/6147K bytes of memory.Processor board ID FDO2127A2C73 Gigabit Ethernet interfaces32768K bytes of non-volatile configuration memory.8388608K bytes of physical memory.7057407K bytes of flash memory at bootflash:.
R0g22
You can deploy your ISR with that IOS. No problem. If you want, you can upgrade to Fuji release which is the latest available aka 16.7.X. If you are concerned about the current IOS, go through the release note for this IOS version and see if their is an Open Caveat that might affect your production -
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/release/notes/isr4451rn.html
And, your router is not in ROMMON mode.
R0g22
