ISR 4431 smart license issue
gushuhua
I  deployed a new ISR4431 on a customer side and  I  have some questions regarding smart licenses.
The ISR was with the version 17.03  delivered and  the smart license is enabled by default.
I have add 51 sip stations  and the station can registerd to cme.  .
The ISR does not support the command "license smart register idtoken" and I did nothing about  the registration. But I  checked the smart account on CSSM, it shows the license "ISR_4440_UnifiedCommuncation"  was purchased and  was in use.
 I  can not sure  whether my isr  has been  registerd to the smart license .  Also i did not know about the the CME_EP license  of which type is "Subscription"and can not sure the sip phone will work well after the 60 days expires.    Do  I  need activate Cisco Smart Licensing Client manually  and how can I do next?
Here you can find the output "show licenses all"  and "show license usage"of my ISR.
#show license all
Smart Licensing Status
Smart Licensing is ENABLED
License Conversion:
Automatic Conversion Enabled: False
Status: Not started
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: ENABLED
Utility report:
Last attempt: NOT STARTED
Customer Information:
Street: <empty>
City: <empty>
State: <empty>
Country: <empty>
Postal Code: <empty>
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: cslu
Cslu address: <empty>
Proxy:
Not Configured
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Sep 19 13:22:47 2022 Beijing
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Jun 21 14:43:53 2022 Beijing
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
License Usage
uck9 (ISR_4400_UnifiedCommunication):
Description: uck9
Count: 1
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: uck9
Feature Description: uck9
Utility Subscription id: <empty>
Enforcement type: NOT ENFORCED
License type: Perpetual
CME_EP (CME_EP):
Description: CME_EP
Count: 51
Version: 1.0
Status: IN USE
Feature Name: CME_EP
Feature Description: CME_EP
License type: Subscription
Product Information
UDI: PID:ISR4431/K9,SN:FOC26170LCC
Agent Version
Smart Agent for Licensing: 5.1.10_rel/38
License Authorizations
Overall status:
Active: PID:ISR4431/K9,SN:FOC25270LCC
Status: NOT INSTALLED
Purchased Licenses:
ISR_4400_UnifiedCommunication (ISR_4400_UnifiedCommunication):
Description: Unified Communications License for Cisco ISR 4400 Series
Total reserved count: 1
Term information:
License type: PERPETUAL
Term Count: 1
#show license usage
License Authorization:
Status: Not Applicable
Description: uck9
Count: 1
Version: 1.0
Status: IN USE
Feature Name: uck9
CME_EP (CME_EP):
Description: CME_EP
Count: 51
Version: 1.0
Status: IN USE
5 Replies 5
Leo Laohoo
The exact IOS-XE version  is Cisco IOS XE Software, Version 17.05.01a
Cisco IOS Software [Bengaluru], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.5.1a,
The Smart Licensing approach is changed from 17.3 onwards.
If we use 'Call-Home' as transport method in the newer version of IOS 17.3 or later, it used 'tools.cisco.com' URL to establish the communication for Smart Licensing.
If we go with the default transport method which is 'Smart URL', it will communicate over 'smartreceiver.cisco.com'
** ensure you have DNS & route to resolve & route both URLs/
Reference URL: https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-xe-17/217046-configure-smart-licensing-using-policy-o.html#anc50
Brief summary of what is required for IOS >= 17.3.
ip domain lookup
ip domain lookup source-interface Loopback0
ip http client source-interface Loopback0
license smart transport callhome
Device(config)# call-home
http resolve-hostname ipv4-first
license smart trust idtoken <TokenID generated from cisco.com> all force
Verification Steps: enter "#show license status" and ensure 1) Last ACK is received & 2) Trust code is showing the date/time
Usage Reporting:
Last ACK received: Jun 24 15:06:34 2022 UTC ---> Last ACK received from CSSM
Next ACK deadline: Sep 21 05:06:34 2022 UTC
Next report push: Jun 23 07:00:30 2022 UTC
Last report push: Jun 23 05:01:33 2022 UTC
Trust Code Installed: Jul 24 18:33:03 2022 UTC ---> should be the date/time the trust code is applied in the router
License Usage
HTH. Pls rate the useful posts to support other community members.
//Suresh Please rate all the useful posts.
 Thank for your suggestion. I have three  questions about  the CME_EP license which type is subscription.
  I  have not see any purchased  license information about  CME_EP license on isr 4431 or the smart account.  I  see only the   ISR_4400_UnifiedCommunication  license.
1) Is the   CME_EP license must purchased by the cisco smart account  through  Cisco Collaboration Flex Plan subscription ?
2) How can I check  whether I  have bought this license on  cisco  smart account ?
3) I  have configured 51 sip stations ,  it will work normally if  the CME_EP  license was not purchased?
#show license usage
Description: uck9
Count: 1
Version: 1.0
Status: IN USE
Feature Name: uck9
CME_EP (CME_EP):
Description: CME_EP
Count: 51
Version: 1.0
Status: IN USE
#show license summary
License Usage:
License Entitlement Tag Count Status
uck9 (ISR_4400_UnifiedCommun...) 1 IN USE
CME_EP (CME_EP) 51 IN USE
