Issue making a call through a POTS Line
I need some better eyes below you'll  see my configuration. I'm attempting to set a small CME to CME but first I trying to dial out to a local number through POTS line. I believe I have everything in place. But when I make a call I get a busy signal.
Its configured to so when you dial 99 but as soon as I do that a busy signal happens
If anyone has time can they take a look and tell what I might be missing to make this call happen. Thank you in advance
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Black-ROIP-Demo
boot-start-marker
boot system flash bootflash:isr4300-universalk9.16.09.05.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$Y3q9$qDetGtNIJEKhZJZ25b5Q2.
no aaa new-model
ip host Black-Demo-ROIP 10.200.65.255
no ip domain lookup
ip domain name Black-Demo-ROIP
ip multicast-routing distributed
ip dhcp excluded-address 10.200.65.19 10.200.65.31
ip dhcp excluded-address 10.201.65.1 10.201.65.2
ip dhcp excluded-address 10.200.65.1 10.200.65.2
ip dhcp pool 1
network 10.200.65.0 255.255.255.128
default-router 10.200.65.2
option 150 ip 10.200.65.2
ip dhcp pool 2
network 10.201.65.0 255.255.255.128
default-router 10.201.65.2
option 150 ip 10.201.65.2
no ip igmp snooping
login on-success log
subscriber templating
trunk group 9_FXO
max-calls any 8
hunt-scheme round-robin
crypto pki trustpoint TP-self-signed-1701876429
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1701876429
revocation-check none
rsakeypair TP-self-signed-1701876429
crypto pki certificate chain TP-self-signed-1701876429
certificate self-signed 01
30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31373031 38373634 3239301E 170D3230 30343238 31393337
33315A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37303138
37363432 39308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
0A028201 0100B9D5 320EC727 2C61468F B044E50D 44C371A0 7A5336AD A34E9CC1
5A2B66DF 6EB9D437 8CE49745 5F8060DF A7FFC9D1 2CE0FD38 78505D6E BB88A7D4
7D0A96FE AB172F6D 6C125B0E 0C7B3339 F7269850 7FBE5E14 FDFDD932 9794B52D
6C313FD6 ECC6FB94 2A04EF6C F0244531 D361C81A 8A782ACA 90B86786 FECB8E06
48B142DB 701955F9 8B852EBA 5701DDFB C886BD52 F38678A1 36D94AB0 154A4177
77FBB876 71518FF1 5D3ECE2F 5C177176 64417C08 9546A63C 7364CE6B B774EB56
ACA524CD 4D25BD35 8FC89F20 886128CA E72BA2C7 1554ABBA 92E05799 6FB31099
94C48D57 D2655DA0 EA6150BC 5232D41E FB6AF6E0 128A02D5 1330CA01 61E66B57
DA99ED44 F9B70203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
301F0603 551D2304 18301680 14113C1F 1D847D9C BEF88ECA 0B082646 A43CF6B3
C7301D06 03551D0E 04160414 113C1F1D 847D9CBE F88ECA0B 082646A4 3CF6B3C7
300D0609 2A864886 F70D0101 05050003 82010100 66885F09 15FEB9A1 E30D659D
563E7E13 41968F76 79E51D2C D4DAB306 EC613E22 3B035A25 21B2FE37 9B237434
99A538DC 29413114 71045BA3 88490076 7058AD25 A9B680F6 38602168 50BF6F56
93D86C8D 70185427 0E28F2FF 3974C447 CAF154CF 6421B547 3ED06CF7 DBEA1B1A
35680ECA AFC50A53 C58CE28D 79AEFE10 67444762 435E696A A44FDA25 F4D02A0A
27E8A1A9 AA729DF5 4BDE9F25 A606D02A 2FEDAE19 2F80DB8A C9653D1F B1F9F2A6
06D5E8CC 87CADE1F F72F5FA8 92299756 F0949E2C 05C0F395 D0C06DC7 44725C0B
C49D322E 7B71B675 3F45EFB7 58F7EE10 4AF31B88 0DC0059B 34B81198 C68C9AAB
6F80E264 FBC65249 D7F9DB5E 2211057D 6D3E58BE
quit
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class permanent 1
signal timing oos timeout disabled
signal keepalive disabled
signal sequence oos no-action
voice class custom-cptone leaving-tone
dualtone conference
frequency 900 900
cadence 150 50 150 50
voice class custom-cptone joining-tone
dualtone conference
frequency 1000 1000
voice register global
mode cme
source-address 10.100.65.255 port 2000
max-dn 20
max-pool 10
load 7962 term62.default.loads
load 7841 sip78xx.12-0-1-11
load 8841 sip88xx.14-0-1-0101-145
load 8851 sipxx.14-0-1-0101-145
load 8851NR sip88xx.14-0-1-0101-145
load 8865 sip8845_65.12-0-1SR1-1
authenticate register
authenticate realm cisco.com
timezone 12
tftp-path flash:
file text
create profile sync 0055714240923512
auto-register
voice register dn 9
number 1000
call-forward b2bua busy 8800
call-forward b2bua noan 8800 timeout 10
name Test1
huntstop channel 1
label 1000
voice register pool 9
busy-trigger-per-button 2
id mac 0008.32A8.6148
type 8851
number 1 dn 9
preference 1
dtmf-relay sip-notify
username 2300 password 2300
description Test1
codec g711ulaw
speed-dial 2 22400 label "PRC-163#1_RT1"
speed-dial 3 22401 label "PRC-163#1_RT2"
speed-dial 4 22402 label "PRC-163#2_RT1"
speed-dial 5 22403 label "PRC-163#2_RT2"
speed-dial 8 22404 label "PRC-163#3_RT1"
speed-dial 9 22405 label "PRC-163#3_RT2"
speed-dial 10 22406 label "PRC-160___HF"
voice-card 0/1
no watchdog
voice-card 0/4
no watchdog
license udi pid ISR4331/K9 sn FLM23270C53
license accept end user agreement
license boot level appxk9
license boot level uck9
license boot level securityk9
no license smart enable
diagnostic bootup level minimal
username admin privilege 15 password 0 password
username 1
username 2300 password 0 2300
redundancy
mode none
bridge-domain 10
interface Loopback0
ip address 10.200.65.255 255.255.255.255
interface GigabitEthernet0/0/0
description *** LAPTOP ***
ip address 10.200.65.249 255.255.255.252
negotiation auto
interface GigabitEthernet0/0/1
ip address 172.26.1.2 255.255.255.240
shutdown
negotiation auto
interface GigabitEthernet0/0/2
description *** Connection to External 3560 ***
ip address dhcp
ip igmp join-group 239.10.250.1
negotiation auto
interface Service-Engine0/1/0
interface Service-Engine0/4/0
interface GigabitEthernet1/0/0
no ip address
negotiation auto
service instance 10 ethernet
encapsulation untagged
bridge-domain 10
interface GigabitEthernet1/0/1
no ip address
negotiation auto
bridge-domain 10
interface GigabitEthernet1/0/2
no ip address
negotiation auto
bridge-domain 10
interface GigabitEthernet1/0/3
no ip address
negotiation auto
bridge-domain 10
interface GigabitEthernet1/0/4
no ip address
negotiation auto
bridge-domain 10
interface GigabitEthernet1/0/5
no ip address
negotiation auto
bridge-domain 10
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vif1
ip address 10.200.65.241 255.255.255.252
ip pim sparse-dense-mode
interface BDI10
ip address 10.200.65.2 255.255.255.128
no ip redirects
no ip proxy-arp
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface Loopback0
ip rtcp report interval 5001
ip default-network 192.168.1.0
ip default-network 10.200.65.0
ip route 10.200.65.0 255.255.255.0 10.200.65.20
ip route 192.168.1.0 255.255.255.0 172.26.1.1
tftp-server flash:/CME-12.0/phone/sccp/7975/apps75.9-4-2ES26.sbn alias apps75.9-4-2ES26.sbn
tftp-server flash:/CME-12.0/phone/sccp/7975/cnu75.9-4-2ES26.sbn alias cnu75.9-4-2ES26.sbn
tftp-server flash:/CME-12.0/phone/sccp/7975/cvm75sccp.9-4-2ES26.sbn alias cvm75sccp.9-4-2ES26.sbn
tftp-server flash:/CME-12.0/phone/sccp/7975/dsp75.9-4-2ES26.sbn alias dsp75.9-4-2ES26.sbn
tftp-server flash:/CME-12.0/phone/sccp/7975/jar75sccp.9-4-2ES26.sbn alias jar75sccp.9-4-2ES26.sbn
tftp-server flash:/CME-12.0/phone/sccp/7975/SCCP75.9-4-2SR3-1S.loads alias SCCP75.9-4-2SR3-1S.loads
tftp-server flash:/CME-12.0/phone/sccp/7975/term75.default.loads alias term75.default.loads
tftp-server bootflash:/CME-12.0/phone/sccp/7962/apps42.9-4-2ES26.sbn alias apps42.9-4-2ES26.sbn
tftp-server bootflash:/CME-12.0/phone/sccp/7962/cnu42.9-4-2ES26.sbn alias cnu42.9-4-2ES26.sbn
tftp-server bootflash:/CME-12.0/phone/sccp/7962/cvm42sccp.9-4-2ES26.sbn alias cvm42sccp.9-4-2ES26.sbn
tftp-server bootflash:/CME-12.0/phone/sccp/7962/dsp42.9-4-2ES26.sbn alias dsp42.9-4-2ES26.sbn
tftp-server bootflash:/CME-12.0/phone/sccp/7962/jar42sccp.9-4-2ES26.sbn alias jar42sccp.9-4-2ES26
tftp-server bootflash:/CME-12.0/phone/sccp/7962/SCCP42.9-4-2SR3-1S.loads alias SCCP42.9-4-2SR3-1S.loads
tftp-server bootflash:/CME-12.0/phone/sccp/7962/term42.default.loads alias term42.default.loads
tftp-server bootflash:/CME-12.0/phone/sccp/7962/term62.default.loads alias term62.default.loads
tftp-server flash:/sip88xx.14-0-1-0101-145.loads
tftp-server flash://sip88xx.14-0-1-0101-145
tftp-server bootflash:vc488xx.12-7-1-0001-393.sbn
control-plane
voice-port 0/1/0
no echo-cancel enable
no comfort-noise
cptone PT
timeouts call-disconnect 3
timeouts wait-release 3
connection plar 1001
impedance complex2
music-threshold -10
threshold noise -30
voice-port 0/1/1
no comfort-noise
cptone PT
connection plar 100
impedance complex2
music-threshold -10
threshold noise -40
voice-port 0/1/2
no comfort-noise
cptone PT
connection plar 100
impedance complex2
music-threshold -10
threshold noise -30
voice-port 0/1/3
no comfort-noise
cptone PT
connection plar 100
impedance complex2
music-threshold -10
threshold noise -30
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
hfs enable
hfs home-path bootflash:/
sdspfarm units 2
sdspfarm transcode sessions 4
sdspfarm tag 1 transcode
sdspfarm tag 2 conference
conference hardware
conference transfer-pattern
max-ephones 40
max-dn 100
ip source-address 10.200.65.255 port 2000
service phone lineMode 1
system message Black RoIP Demo
cnf-file location flash:
cnf-file perphone
load 7962 SCCP42.9-4-2SR3-1S
load 7975 SCCP75.9-4-2SR3-1S
time-zone 12
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
dspfarm profile 1 transcode
associate application SCCP
shutdown
dial-peer voice 400 pots
description // PRC-152A LMR \\
destination-pattern 22400
incoming called-number 22400
port 0/1/0
dial-peer voice 401 pots
description // Spare 1 \\
destination-pattern 22401
incoming called-number 22401
port 0/1/1
dial-peer voice 403 pots
description // Spare 3 \\
destination-pattern 22403
incoming called-number 22403
port 0/1/3
dial-peer voice 9911 pots
trunkgroup 9_FXO
description ****** 9 + 911 Emergency ******
destination-pattern 9911
forward-digits 3
dial-peer voice 911 pots
trunkgroup 9_FXO
description ****** 911 Emergency ******
destination-pattern 911
forward-digits 3
dial-peer voice 900 pots
trunkgroup 9_FXO
description ****** 9 + any X11 number ******
destination-pattern 9[2-8]11
forward-digits 3
dial-peer voice 901 pots
trunkgroup 9_FXO
description ****** 9 + access ******
destination-pattern 9.......
forward-digits 10
dial-peer voice 902 pots
trunkgroup 9_FXO
description ****** 99 + access ******
destination-pattern 99.......
forward-digits 11
dial-peer voice 903 pots
trunkgroup 9_FXO
description ****** 9 + 1 Long Distance access ******
destination-pattern 91[2-9]..[2-9]......
forward-digits 11
dial-peer voice 904 pots
trunkgroup 9_FXO
description ****** 9 + 011 overseas access ******
destination-pattern 9011T
prefix 011
dial-peer voice 123 pots
description Outbound
incoming called-number 4126
port 0/1/0
forward-digits 11
dial-peer voice 99 pots
trunkgroup 9_FXO
description ****** 99 ******
destination-pattern 99,
forward-digits 11
num-exp 0 1000
gateway
media-inactivity-criteria all
timer receive-rtp 1200
sip-ua
ephone-template 1
conference admin
softkeys hold Resume Newcall Select Join
softkeys idle Redial Newcall ConfList RmLstC Cfwdall Join Pickup Login HLog Dnd Gpickup
softkeys seized Endcall Redial Cfwdall Meetme Pickup Callback
softkeys alerting Endcall Callback
softkeys connected Hold Endcall Confrn Trnsfer Select Join ConfList RmLstC Park Flash
max-calls-per-button 1
button-layout 1-2 line
button-layout 3-6 speed-dial
type 7962
ephone-template 2
conference admin
button-layout 3-8 speed-dial
ephone-template 3
conference admin
button-layout 1 line
button-layout 2 speed-dial
ephone-dn 1
number 1000
name Secure Operator
call-forward busy 1001
call-forward noan 1001 timeout 10
ephone-dn 2
number 1001
name Viper 23
call-forward busy 1000
call-forward noan 1000 timeout 10
ephone-dn 3
number 1002
name Gordon
call-forward busy 1004
call-forward noan 1003 timeout 10
ephone-dn 4
number 1003
description Gordon
name Viper (Secure)
call-forward busy 1002
call-forward noan 1002 timeout 10
ephone-dn 5
number 2100
description OFFICE 1 ()
name OFFICE 1
ephone-dn 6
number 2101
name OFFICE 1
ephone-dn 7
number 2200
description OFFICE 2 ()
name OFFICE 2
ephone-dn 8
number 2201
name OFFICE 2
ephone-dn 9
number 2300
description Office 3 ()
name Office 3
ephone-dn 10
number 2301
description OFFICE 3 ()
name Office 3
ephone-dn 11
number 3100
description User 1
name User 1
ephone-dn 12
number 3101
description User 1
name User 1
ephone-dn 13
number 3200
description User 2
name User 2
ephone-dn 14
number 3201
description User 2
name User 2
ephone-dn 15
number 3300
description User 3
name User 3
ephone-dn 16
number 3301
description User 3
name User 3
ephone-dn 17
number 3400
description User 4
name User 4
ephone-dn 18
number 3401
description User 4
name User 4
ephone-dn 19
number 3500
description User 5
name User 5
ephone-dn 20
number 3501
description User 5
name User 5
ephone-dn 40
number 22400
name PRC-152A LMR
ephone-dn 41
number 22401
name Spare 1
ephone-dn 42
number 22402
name Spare 2
ephone-dn 43
number 22403
name Spare 3
ephone 2
device-security-mode none
mac-address DCA5.F486.0F6D
ephone-template 1
type 7962
button 1:3 2:4
ephone 3
mac-address 0050.C219.26B1
ephone-template 1
type 7962
button 1:2 2:4
ephone 4
mac-address E804.6213.D622
ephone-template 1
type 7962
button 1:1 2:2
ephone 9
description ** Test1 **
mac-address 0008.32A8.6148
ephone-template 3
speed-dial 1 22400 label "PRC-163#1_RT1"
button 1:1 2:2 3:3 4:4
button 5:5 8:8 9:9 10:10
line con 0
logging synchronous
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password redenter
login
end
Black-ROIP-Demo(config)#
version 16.9
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
no ip domain lookup
ip dhcp pool 1
ip dhcp pool 2
no ip igmp snooping
trunk group 9_FXO
max-calls any 8
quit
voice service voip
dualtone conference
frequency 900 900
dualtone conference
frequency 1000 1000
mode cme
max-dn 20
max-pool 10
timezone 12
tftp-path flash:
file text
auto-register
voice register dn 9
number 1000
name Test1
huntstop channel 1
label 1000
type 8851
number 1 dn 9
preference 1
description Test1
codec g711ulaw
voice-card 0/1
no watchdog
voice-card 0/4
no watchdog
username 1
username xxxxx xxxxxx
redundancy
mode none
bridge-domain 10
interface Loopback0
negotiation auto
shutdown
negotiation auto
ip address dhcp
negotiation auto
no ip address
negotiation auto
bridge-domain 10
no ip address
negotiation auto
bridge-domain 10
no ip address
negotiation auto
bridge-domain 10
no ip address
negotiation auto
bridge-domain 10
no ip address
negotiation auto
bridge-domain 10
no ip address
negotiation auto
bridge-domain 10
no ip address
shutdown
negotiation auto
interface Vif1
interface BDI10
no ip redirects
no ip proxy-arp
ip http server
control-plane
voice-port 0/1/0
no comfort-noise
cptone PT
impedance complex2
music-threshold -10
threshold noise -30
voice-port 0/1/1
no comfort-noise
cptone PT
connection plar 100
impedance complex2
music-threshold -10
threshold noise -40
voice-port 0/1/2
no comfort-noise
cptone PT
connection plar 100
impedance complex2
music-threshold -10
threshold noise -30
voice-port 0/1/3
no comfort-noise
cptone PT
connection plar 100
impedance complex2
music-threshold -10
threshold noise -30
telephony-service
hfs enable
sdspfarm units 2
conference hardware
max-ephones 40
max-dn 100
cnf-file perphone
time-zone 12
shutdown
port 0/1/0
port 0/1/1
port 0/1/3
trunkgroup 9_FXO
forward-digits 3
trunkgroup 9_FXO
forward-digits 3
trunkgroup 9_FXO
forward-digits 3
trunkgroup 9_FXO
forward-digits 10
trunkgroup 9_FXO
forward-digits 11
trunkgroup 9_FXO
forward-digits 11
trunkgroup 9_FXO
prefix 011
port 0/1/0
forward-digits 11
trunkgroup 9_FXO
forward-digits 11
num-exp 0 1000
gateway
sip-ua
ephone-template 1
conference admin
type 7962
ephone-template 2
conference admin
ephone-template 3
conference admin
ephone-dn 1
number 1000
ephone-dn 2
number 1001
name Viper 23
ephone-dn 3
number 1002
name Gordon
ephone-dn 4
number 1003
description Gordon
name Viper (Secure)
ephone-dn 5
number 2100
name OFFICE 1
ephone-dn 6
number 2101
name OFFICE 1
ephone-dn 7
number 2200
name OFFICE 2
ephone-dn 8
number 2201
name OFFICE 2
ephone-dn 9
number 2300
name Office 3
ephone-dn 10
number 2301
name Office 3
ephone-dn 11
number 3100
description User 1
name User 1
ephone-dn 12
number 3101
description User 1
name User 1
ephone-dn 13
number 3200
description User 2
name User 2
ephone-dn 14
number 3201
description User 2
name User 2
ephone-dn 15
number 3300
description User 3
name User 3
ephone-dn 16
number 3301
description User 3
name User 3
ephone-dn 17
number 3400
description User 4
name User 4
ephone-dn 18
number 3401
description User 4
name User 4
ephone-dn 19
number 3500
description User 5
name User 5
ephone-dn 20
number 3501
description User 5
name User 5
ephone-dn 40
number 22400
name PRC-152A LMR
ephone-dn 41
number 22401
name Spare 1
ephone-dn 42
number 22402
name Spare 2
ephone-dn 43
number 22403
name Spare 3
ephone 2
ephone-template 1
type 7962
button 1:3 2:4
ephone 3
mac-address xxxx.xxxx.xxxx
ephone-template 1
type 7962
button 1:2 2:4
ephone 4
ephone-template 1
type 7962
button 1:1 2:2
ephone 9
ephone-template 3
line con 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password redenter
login
end
7 Replies 7
Jesse3620
"Its configured to so when you dial 99 but as soon as I do that a busy signal happen" - So you're using 99 as your access code for callers to reach the PSTN?
This dial-peer is probably causing this issue then:
port 0/1/0
forward-digits 11
I'm not sure what role that dial-peer is playing in your config, but it's most likely causing the fast busy after you dial 99. I would remove it, run debug voip dial peer w/ term mon and make another outbound call. From there you can see what dial peers are being used currently and go from there. Also, I'm thinking the trunk group commands should be entered under your voice ports.
Yea sorry that wasn't it. When I removed I got the busy signal right away. When I put it back I noticed the signal was delayed but yet a busy signal.
port 0/1/0
forward-digits 11
when I ran voice port summary command I notice that
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/1/0 -- fxo-ls up dorm idle on-hook n
0/1/1 -- fxo-ls up dorm idle on-hook n
0/1/2 -- fxo-ls up dorm idle on-hook n
0/1/3 -- fxo-ls down down idle on-hook n
50/0/1 1 efxs up dorm on-hook idle y
50/0/2 1 efxs up dorm on-hook idle y
50/0/3 1 efxs up dorm on-hook idle y
50/0/4 1 efxs up dorm on-hook idle y
50/0/5 1 efxs up up on-hook idle y
50/0/6 1 efxs up up on-hook idle y
50/0/7 1 efxs up up on-hook idle y
50/0/8 1 efxs up up on-hook idle y
50/0/9 1 efxs up up on-hook idle y
50/0/10 1 efxs up up on-hook idle y
50/0/11 1 efxs up up on-hook idle y
50/0/12 1 efxs up up on-hook idle y
50/0/13 1 efxs up up on-hook idle y
50/0/14 1 efxs up up on-hook idle y
50/0/15 1 efxs up up on-hook idle y
50/0/16 1 efxs up up on-hook idle y
My phones are up under Virtual ports 50/0/1 through 50/0/3
Not sure what you are trying to achieve, Since you have a dial-peer with destination pattern 99, that will be matched when you dial 99 and it wont hit the other dial-peers you have.
port 0/1/0
forward-digits 11
Rajan
Please rate all useful posts by clicking the star below and mark solutions as accepted wherever applicable
What you are trying to achieve with the below dial-peer.
port 0/1/0
forward-digits 11
Response Signature
Thank you for responding
I inherited this config and I'm not experienced enough to know which dial-peers are needed and not needed. From the set up shown on e current config shows 3 phones configured. Those phones can all call each through their dn- number. I have a FXO port with a, (RJ-11 cable) plugged in. The RJ-11 has been converted to an ethernet cable that is plugged into a phone port. That desk phone was plugged into
I have been attempting to figure out how to get. The configured phones to make an outside call through the FXO port.
The end goal is to have two CME routers connected by SFP and have the ability to call out over a POTS line
Or am I thinking about this all wrong.
Thanks you for taking the time to help....
"I have a FXO port with a, (RJ-11 cable) plugged in. The RJ-11 has been converted to an ethernet cable that is plugged into a phone port. That desk phone was plugged into" FXO port are used for PSTN connection, not for connecting phones. if you need to connect analogue  phone  use  FXS.
If your requirement is to connect two CME, you can do it using IP connectivity .There is no need to connect it using  pots. Is  this a production  environment or lab. if its production environment, I would recommend to involve someone  who is good in VOICE.
Response Signature
Thanks again for the help I might be making some head way.
I basically am trying to pull this thing apart and learn from scratch. I have just kept two of the Dial-peers
and I'm at least able to dial 9+1 then a number it sit there and then becomes a busy signal. I did test the fax line so I know I can dial out on that its they are both connect through a rj-11 cable.
4126 is the ext the fax number is under.
trunkgroup 9_FXO
destination-pattern 91..........
forward-digits 11
port 0/1/0
forward-digits 11
