Issues on SRST
mohammedmon
Dear Sir,
We have two Sites .example site A and Site B.call manager Bussiness Edition 6000 is placed in site-A and Site-B phones are registered on this BE 6000 through VPN.In Site-B there is a SRST Router  for  the redundancy
In site-B there is cisco 7975,7962 ,cp 6921 and cp7861 iphones
After finishing the configuration 7675 and 7962 is able to register on srst router after loss the connectivity of BE 6000.but  cp 6921 and cp7861 iphones are not registering on srst router.Please help me
Find the configuration SRST Router. Please let me know if  i should make changes
Current configuration : 6139 bytes
! Last configuration change at 17:51:36 PCTime Sat Mar 26 2016
version 15.4
hostname AUH_SRST
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
logging queue-limit 10000
logging buffered 10000000
logging rate-limit 10000
no logging console
no logging monitor
enable password admin
no aaa new-model
clock timezone PCTime 4 0
ip dhcp excluded-address 192.168.50.129
ip dhcp excluded-address 192.168.50.130
ip dhcp pool VOICE
import all
network 192.168.50.128 255.255.255.128
default-router 192.168.50.130
option 150 ip 10.10.3.251 10.10.3.250
lease 30
no ip domain lookup
ip cef
no ipv6 cef
trunk group AUH_FXO
hunt-scheme round-robin
cts logging verbose
crypto pki trustpoint TP-self-signed-2478824890
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2478824890
revocation-check none
rsakeypair TP-self-signed-2478824890
crypto pki certificate chain TP-self-signed-2478824890
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32343738 38323438 3930301E 170D3136 30333235 31323432
34395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 34373838
32343839 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100E4CD 2139B19F 3BCE42FC 994431B7 E2D27BD5 374A9DBE 41737545 3E42F435
73969AB6 498B1026 710ACDFD EDC02DF2 2DA1F7B8 78ECBE76 9DDE349A 00449610
D655FC06 1D74AE58 A0A65B42 F231141D 8332DD1F D0F05F8F DB7B0BCE 6DC7577E
836A5D8A A72A9804 D7785951 C2E38BCC 7A762EAC 07C65C84 6EC1C511 6A116847
01B10203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14162F30 7B18FC5F 4479F0BF 0AF244A2 6D778500 E7301D06
03551D0E 04160414 162F307B 18FC5F44 79F0BF0A F244A26D 778500E7 300D0609
2A864886 F70D0101 05050003 81810022 C97EB889 83830CFE 5A804C71 781A6C26
9FD6AFE6 48FC7530 C379C565 018A2CE3 9EB08D9C 60E4AED4 B4BC3A9B 4163C3A6
D413719C 7A41FE43 668D69F1 25F502AD CF3D75D2 2EAFA1AF C5E2D472 533BDBDC
2A0769EB 57AD8DCB B711275E EDE146DD CBA3D005 F76DCBB6 84FAAEF1 A35BB0B0
B376DC22 2F1D9DBD FDC5ACEF 5FA609
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice iec syslog
voice register global
mode srst
voice translation-rule 1
rule 1 /[0-9]+/ /9&/
rule 2 /971/ /900971&/
voice translation-profile FROM_ISP
translate calling 1
application
global
service alternate default
license udi pid CISCO2921/K9 sn FCZ193661MR
hw-module pvdm 0/0
username admin privilege 15 password 0 admin
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description #MANAGEMENT#
encapsulation dot1Q 10
ip address 192.168.22.5 255.255.255.248
interface GigabitEthernet0/0.60
description #vOICE vLAN#
encapsulation dot1Q 60
ip address 192.168.50.130 255.255.255.128
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.50.130
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.50.129
logging trap debugging
control-plane
voice-port 0/0/0
trunk-group AUH_FXO
translation-profile incoming FROM_ISP
cptone AE
timeouts call-disconnect 5
timeouts wait-release 5
timing guard-out 1000
connection plar opx 5333
caller-id enable
voice-port 0/0/1
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/2
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/3
trunk-group AUH_FXO
cptone AE
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
incoming called-number .
dial-peer voice 1000 voip
destination-pattern 5333
session target ipv4:10.10.3.250
voice-class codec 1
dial-peer voice 1001 voip
destination-pattern 53..
voice-class codec 1
sip-ua
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 192.168.50.130 port 2000
max-ephones 25
max-dn 50 dual-line
system message primary MELCO_LOCAL
system message secondary MELCO_LOCAL
transfer-pattern .T
keepalive 20
call-forward pattern .T
call-forward busy 5333
call-forward noan 5333 timeout 45
time-zone 35
date-format dd-mm-yy
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password admin
login
transport input telnet
scheduler allocate 20000 1000
end
Amit23
Level 4
Level 4
try this step for 7821..
voice service voip
 sip
 system message SRST Active
 max-dn 50
 max-pool 19
voice register pool  1
 id network xx.xx.xx.xx mask xx.xx.xx.xx
 dtmf-relay rtp-nte cisco-rtp sip-notify
 codec g711ulaw
 no vad
sip-ua
 registrar ipv4:yy.yy.yy.yy expires 600
On UCM SRST reference configuration for gateway
SIP Network/IP Address : yy.yy.yy.yy
SIP Port :  5060
for xx.xx.xx.xx insert the network ID
for yy.yy.yy.yy insert Gateway IP
he 7841 phone is a revision of the older 6941 phone and it needs to be referenced in the config.(Fast Track Configuration)
New SIP Phone models validated for CME using Fast-track configuration
voice register pool-type 7841
description Cisco IP Phone 7841
reference-pooltype 6941
"Once the new SIP phone model is configured using the fast-track configuration approach, the new phone model can be provisioned using the existing voice register pool configuration option as shown below."
Below is the link that references the above commands.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmebasic.html#pgfId-1295535
Hope this helps.
Warm Regard's
Amit Sahrma
Thanks for good advise
Please find below call-manager-fallback details and please let me know how to solve this issue
#Sh call-manager-fallback all
CONFIG (Version=10.5)
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 25
max-dn 50 dual-line
dspfarm units 0
dspfarm transcode sessions 0
huntstop
no huntstop channel
huntstop channel 0
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
timezone 35 Arabian Standard Time
transfer-pattern .T
keepalive 20 auxiliary 30
timeout interdigit 5
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message primary ETA_MELCO_LOCAL
system message secondary ETA_MELCO_LOCAL
Limit number of DNs per phone:
12SP: 76
7902: 76
7905: 76
7906: 76
7910: 76
7911: 76
7912: 76
7920: 76
7921: 76
7925: 76
7931: 76
7935: 76
7936: 76
7937: 76
7940: 76
7941: 76
7941GE: 76
7942: 76
7945: 76
7960: 76
7961: 76
7961GE: 76
7962: 76
7965: 76
7970: 76
7971: 76
7975: 76
7985: 76
anl: 76
ata: 76
bri: 76
CIPC: 76
vgc-phone: 76
IP-STE: 76
6921: 76
6941: 76
6961: 76
6901: 76
6911: 76
7926: 76
6945: 76
8941: 76
8945: 76
Log (table parameters):
max-size: 150
retain-timer: 15
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
ephone-dn 1 dual-line
preference 0 secondary 9
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 2 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 3 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 4 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 5 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 6 dual-line
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 7 dual-line
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 8 dual-line
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 9 dual-line
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 10 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 11 dual-line
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 12 dual-line
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 13 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 14 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 15 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 16 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 17 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 18 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 19 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 20 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 21 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 22 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 23 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 24 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 25 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 26 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 27 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 28 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 29 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 30 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 31 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 32 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 33 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 34 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 35 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 36 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 37 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 38 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 39 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 40 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 41 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 42 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 43 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 44 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 45 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 46 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 47 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 48 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 49 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 50 dual-line
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
Number of Configured ephones 0 (Registered 0)
voice-port 50/0/1
timeout ringing 45
voice-port 50/0/2
timeout ringing 45
voice-port 50/0/3
timeout ringing 45
voice-port 50/0/4
timeout ringing 45
voice-port 50/0/5
timeout ringing 45
voice-port 50/0/6
timeout ringing 45
voice-port 50/0/7
timeout ringing 45
voice-port 50/0/8
timeout ringing 45
voice-port 50/0/9
timeout ringing 45
voice-port 50/0/10
timeout ringing 45
voice-port 50/0/11
timeout ringing 45
voice-port 50/0/12
timeout ringing 45
voice-port 50/0/13
voice-port 50/0/14
voice-port 50/0/15
voice-port 50/0/16
voice-port 50/0/17
voice-port 50/0/18
voice-port 50/0/19
voice-port 50/0/20
voice-port 50/0/21
voice-port 50/0/22
voice-port 50/0/23
voice-port 50/0/24
voice-port 50/0/25
voice-port 50/0/26
voice-port 50/0/27
voice-port 50/0/28
voice-port 50/0/29
voice-port 50/0/30
voice-port 50/0/31
voice-port 50/0/32
voice-port 50/0/33
voice-port 50/0/34
voice-port 50/0/35
voice-port 50/0/36
voice-port 50/0/37
voice-port 50/0/38
voice-port 50/0/39
voice-port 50/0/40
voice-port 50/0/41
voice-port 50/0/42
voice-port 50/0/43
voice-port 50/0/44
voice-port 50/0/45
voice-port 50/0/46
voice-port 50/0/47
voice-port 50/0/48
voice-port 50/0/49
voice-port 50/0/50
dial-peer voice 20001 pots
huntstop
progress_ind setup enable 3
port 50/0/1
dial-peer voice 20002 pots
huntstop
port 50/0/2
dial-peer voice 20003 pots
huntstop
port 50/0/3
dial-peer voice 20004 pots
huntstop
port 50/0/4
dial-peer voice 20005 pots
huntstop
port 50/0/5
dial-peer voice 20006 pots
huntstop
port 50/0/6
dial-peer voice 20007 pots
huntstop
port 50/0/7
dial-peer voice 20008 pots
huntstop
port 50/0/8
dial-peer voice 20009 pots
huntstop
port 50/0/9
dial-peer voice 20010 pots
huntstop
port 50/0/10
dial-peer voice 20011 pots
huntstop
port 50/0/11
dial-peer voice 20012 pots
huntstop
port 50/0/12
dial-peer voice 20013 pots
huntstop
port 50/0/13
dial-peer voice 20014 pots
huntstop
port 50/0/14
dial-peer voice 20015 pots
huntstop
port 50/0/15
dial-peer voice 20016 pots
huntstop
port 50/0/16
dial-peer voice 20017 pots
huntstop
port 50/0/17
dial-peer voice 20018 pots
huntstop
port 50/0/18
dial-peer voice 20019 pots
huntstop
port 50/0/19
dial-peer voice 20020 pots
huntstop
port 50/0/20
dial-peer voice 20021 pots
huntstop
port 50/0/21
dial-peer voice 20022 pots
huntstop
port 50/0/22
dial-peer voice 20023 pots
huntstop
port 50/0/23
dial-peer voice 20024 pots
huntstop
port 50/0/24
dial-peer voice 20025 pots
huntstop
port 50/0/25
dial-peer voice 20026 pots
huntstop
port 50/0/26
dial-peer voice 20027 pots
huntstop
port 50/0/27
dial-peer voice 20028 pots
huntstop
port 50/0/28
dial-peer voice 20029 pots
huntstop
port 50/0/29
dial-peer voice 20030 pots
huntstop
port 50/0/30
dial-peer voice 20031 pots
huntstop
port 50/0/31
dial-peer voice 20032 pots
huntstop
port 50/0/32
dial-peer voice 20033 pots
huntstop
port 50/0/33
dial-peer voice 20034 pots
huntstop
port 50/0/34
dial-peer voice 20035 pots
huntstop
port 50/0/35
dial-peer voice 20036 pots
huntstop
port 50/0/36
dial-peer voice 20037 pots
huntstop
port 50/0/37
dial-peer voice 20038 pots
huntstop
port 50/0/38
dial-peer voice 20039 pots
huntstop
port 50/0/39
dial-peer voice 20040 pots
huntstop
port 50/0/40
dial-peer voice 20041 pots
huntstop
port 50/0/41
dial-peer voice 20042 pots
huntstop
port 50/0/42
dial-peer voice 20043 pots
huntstop
port 50/0/43
dial-peer voice 20044 pots
huntstop
port 50/0/44
dial-peer voice 20045 pots
huntstop
port 50/0/45
dial-peer voice 20046 pots
huntstop
port 50/0/46
dial-peer voice 20047 pots
huntstop
port 50/0/47
dial-peer voice 20048 pots
huntstop
port 50/0/48
dial-peer voice 20049 pots
huntstop
port 50/0/49
dial-peer voice 20050 pots
huntstop
port 50/0/50
USER DEFINED 0 TAG PHRASES:
tag 0 CM Fallback Service Operating
tag 1 Max Phones Exceeded
tag 2 Waiting to Re-Home
tag 3 Please End Call
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 7 No Line Available
tag 8 Unable to Transfer
tag 9 Transfer-To is Busy
tag 10 Cisco IOS Telephony Service
tag 11 Local Services
tag 12 Select A Service
tag 13 Local Directory
tag 14 Local Speed Dial
tag 15 Enter search criteria
tag 16 Last Name
tag 17 First Name
tag 18 Local Directory Search
tag 19 Too many matches. Please refine your search.
tag 20 Search Results
tag 21 No Record Found.
tag 22 Records 1 to
tag 23 of
tag 24 Please enter PIN
tag 25 Wrong PIN
tag 26 Login Successful
tag 27 Night Service Disabled
tag 28 Night Service Active
tag 29 Night Service
tag 30 Private
tag 31 Conferee List
tag 32 Make Your Selection
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 38 Temporary failure
tag 39 conference dropped by host
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 43 Transfer Recall From
tag 44 My Phone Apps
tag 45 Speed Dial Buttons
tag 46 Personal Speed Dial
tag 47 Reset Phone
tag 48 This function is not enabled
tag 49 Add
tag 50 Change
tag 51 Extension Mobility
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 55 Logging in ...
tag 56 Login failed, authentication error! Please try again.
tag 57 Music
tag 58 MLPP Block Precedence
tag 59 Mobility
tag 60 MobileConnect
tag 61 On
tag 62 Off
tag 63 Press Exit to Return
tag 64 You are not a valid Mobile Phone User
tag 65 Send Call To Mobile Phone
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 69 After Hours Login
tag 70 IP Phone logout?
tag 71 Logout Successful
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 75 Single Number Reach
tag 76 Invalid Number
tag 77 Please Modify Number
tag 78 Joined To Hunt Group
tag 79 Lable
tag 80 Number
tag 81 Resetting, Press Exit
tag 82 SNR is not configured
tag 83 Please configure SNR
tag 84 Please enter new information
tag 85 Please enter information
tag 86 New Personal Speed Dial Entry
tag 87 New Speed Dial Button Entry
tag 88 New BLF Speed Dial Button Entry
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 92 SNR can't be same dn number
tag 93 Access Mailbox
tag 94 Invalid speed dial number
tag 95 Invalid personal speed dial number
tag 96 Invalid BLF speed dial number
tag 97 Personal speed dial number can not exceed 32 digits
tag 98 Personal speed dial label can not exceed 30 characters
tag 99 Speed dial number can not exceed 24 digits
tag 100 The record is full
tag 101 Please delete unused entry
tag 102 Logging Out
tag 103 Please configure different SNR#
tag 104 CME hardware conference
tag 105 CME software conference
tag 106 add party allowed
tag 107 add party not allowed
tag 108 CME group pickup
tag 109 CME pickup
tag 110 Failed to send call to Mobile Phone
tag 111 Live Record is not enable
tag 112 Live Record already in progress
tag 113 Not conference creator
tag 114 Live Record has stopped
tag 115 Live Record timeout
tag 116 CME Service URLs
tag 117 %d calls in queue
tag 118 Records of %d to %d of %d
tag 119 Transfer Disabled
tag 120 Conference Resource Unavailable
tag 121 Early conference not supported
tag 122 Divert call to Voicemail
tag 123 Select Divert Destination
tag 124 Voice Hunt Groups
tag 125 Joined to HG %s & %d more
tag 126 Join
tag 127 Unjoin
tag 128 Join Successful
tag 129 Unjoin Successful
tag 130 Join Failed
tag 131 Unjoin Failed
tag 132 Hunt Group Error
tag 133 Join Limit Exceeds
tag 134 Parked Call List
tag 135 No Active Parked Calls
tag 136 Name
tag 137 Back
tag 138 Submit
tag 139 After Hours Logout
tag 140 Login failed, invalid PIN number! Please try again.
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
USER DEFINED 1 TAG PHRASES:
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
USER DEFINED 2 TAG PHRASES:
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
USER DEFINED 3 TAG PHRASES:
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
USER DEFINED 4 TAG PHRASES:
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
License Supported:
cme-srst: Registered, In Use. Handle: 0xFA00000A
Maximum User License: 110
CSL license count: 110
CSL Requested User License: 25
Used User License: 0
Available User License: 110
Max Users Provisioned (ephone + pool): 25
Allowance - Extra user license: 0
temp_license_expired_event: 0
license_installed_event: 0
license_count_change_event: 0
eula_not_accepted: 0
license_check_approved: 27
license_check_denied: 0
Version 10.5
ip qos dscp:
max-ephones 25
max-dn 50 dual-line
dspfarm units 0
huntstop
no huntstop channel
huntstop channel 0
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
time-format 12
transfer-pattern .T
timeout busy 10
timeout ringing 180
12SP: 76
7902: 76
7905: 76
7906: 76
7910: 76
7911: 76
7912: 76
7920: 76
7921: 76
7925: 76
7931: 76
7935: 76
7936: 76
7937: 76
7940: 76
7941: 76
7941GE: 76
7942: 76
7945: 76
7960: 76
7961: 76
7961GE: 76
7962: 76
7965: 76
7970: 76
7971: 76
7975: 76
7985: 76
anl: 76
ata: 76
bri: 76
CIPC: 76
vgc-phone: 76
IP-STE: 76
6921: 76
6941: 76
6961: 76
6901: 76
6911: 76
7926: 76
6945: 76
8941: 76
8945: 76
max-size: 150
retain-timer: 15
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
voice-port 50/0/1
timeout ringing 45
voice-port 50/0/2
timeout ringing 45
voice-port 50/0/3
timeout ringing 45
voice-port 50/0/4
timeout ringing 45
voice-port 50/0/5
timeout ringing 45
voice-port 50/0/6
timeout ringing 45
voice-port 50/0/7
timeout ringing 45
voice-port 50/0/8
timeout ringing 45
voice-port 50/0/9
timeout ringing 45
voice-port 50/0/10
timeout ringing 45
voice-port 50/0/11
timeout ringing 45
voice-port 50/0/12
timeout ringing 45
voice-port 50/0/13
voice-port 50/0/14
voice-port 50/0/15
voice-port 50/0/16
voice-port 50/0/17
voice-port 50/0/18
voice-port 50/0/19
voice-port 50/0/20
voice-port 50/0/21
voice-port 50/0/22
voice-port 50/0/23
voice-port 50/0/24
voice-port 50/0/25
voice-port 50/0/26
voice-port 50/0/27
voice-port 50/0/28
voice-port 50/0/29
voice-port 50/0/30
voice-port 50/0/31
voice-port 50/0/32
voice-port 50/0/33
voice-port 50/0/34
voice-port 50/0/35
voice-port 50/0/36
voice-port 50/0/37
voice-port 50/0/38
voice-port 50/0/39
voice-port 50/0/40
voice-port 50/0/41
voice-port 50/0/42
voice-port 50/0/43
voice-port 50/0/44
voice-port 50/0/45
voice-port 50/0/46
voice-port 50/0/47
voice-port 50/0/48
voice-port 50/0/49
voice-port 50/0/50
huntstop
port 50/0/1
huntstop
port 50/0/2
huntstop
port 50/0/3
huntstop
port 50/0/4
huntstop
port 50/0/5
huntstop
port 50/0/6
huntstop
port 50/0/7
huntstop
port 50/0/8
huntstop
port 50/0/9
huntstop
port 50/0/10
huntstop
port 50/0/11
huntstop
port 50/0/12
huntstop
port 50/0/13
huntstop
port 50/0/14
huntstop
port 50/0/15
huntstop
port 50/0/16
huntstop
port 50/0/17
huntstop
port 50/0/18
huntstop
port 50/0/19
huntstop
port 50/0/20
huntstop
port 50/0/21
huntstop
port 50/0/22
huntstop
port 50/0/23
huntstop
port 50/0/24
huntstop
port 50/0/25
huntstop
port 50/0/26
huntstop
port 50/0/27
huntstop
port 50/0/28
huntstop
port 50/0/29
huntstop
port 50/0/30
huntstop
port 50/0/31
huntstop
port 50/0/32
huntstop
port 50/0/33
huntstop
port 50/0/34
huntstop
port 50/0/35
huntstop
port 50/0/36
huntstop
port 50/0/37
huntstop
port 50/0/38
huntstop
port 50/0/39
huntstop
port 50/0/40
huntstop
port 50/0/41
huntstop
port 50/0/42
huntstop
port 50/0/43
huntstop
port 50/0/44
huntstop
port 50/0/45
huntstop
port 50/0/46
huntstop
port 50/0/47
huntstop
port 50/0/48
huntstop
port 50/0/49
huntstop
port 50/0/50
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
License Supported:
Version 10.5
ip qos dscp:
max-ephones 25
max-dn 50 dual-line
dspfarm units 0
huntstop
no huntstop channel
huntstop channel 0
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
time-format 12
transfer-pattern .T
timeout busy 10
timeout ringing 180
12SP: 76
7902: 76
7905: 76
7906: 76
7910: 76
7911: 76
7912: 76
7920: 76
7921: 76
7925: 76
7931: 76
7935: 76
7936: 76
7937: 76
7940: 76
7941: 76
7941GE: 76
7942: 76
7945: 76
7960: 76
7961: 76
7961GE: 76
7962: 76
7965: 76
7970: 76
7971: 76
7975: 76
7985: 76
anl: 76
ata: 76
bri: 76
CIPC: 76
vgc-phone: 76
IP-STE: 76
6921: 76
6941: 76
6961: 76
6901: 76
6911: 76
7926: 76
6945: 76
8941: 76
8945: 76
max-size: 150
retain-timer: 15
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
voice-port 50/0/1
timeout ringing 45
voice-port 50/0/2
timeout ringing 45
voice-port 50/0/3
timeout ringing 45
voice-port 50/0/4
timeout ringing 45
voice-port 50/0/5
timeout ringing 45
voice-port 50/0/6
timeout ringing 45
voice-port 50/0/7
timeout ringing 45
voice-port 50/0/8
timeout ringing 45
voice-port 50/0/9
timeout ringing 45
voice-port 50/0/10
timeout ringing 45
voice-port 50/0/11
timeout ringing 45
voice-port 50/0/12
timeout ringing 45
voice-port 50/0/13
voice-port 50/0/14
voice-port 50/0/15
voice-port 50/0/16
voice-port 50/0/17
voice-port 50/0/18
voice-port 50/0/19
voice-port 50/0/20
voice-port 50/0/21
voice-port 50/0/22
voice-port 50/0/23
voice-port 50/0/24
voice-port 50/0/25
voice-port 50/0/26
voice-port 50/0/27
voice-port 50/0/28
voice-port 50/0/29
voice-port 50/0/30
voice-port 50/0/31
voice-port 50/0/32
voice-port 50/0/33
voice-port 50/0/34
voice-port 50/0/35
voice-port 50/0/36
voice-port 50/0/37
voice-port 50/0/38
voice-port 50/0/39
voice-port 50/0/40
voice-port 50/0/41
voice-port 50/0/42
voice-port 50/0/43
voice-port 50/0/44
voice-port 50/0/45
voice-port 50/0/46
voice-port 50/0/47
voice-port 50/0/48
voice-port 50/0/49
voice-port 50/0/50
huntstop
port 50/0/1
huntstop
port 50/0/2
huntstop
port 50/0/3
huntstop
port 50/0/4
huntstop
port 50/0/5
huntstop
port 50/0/6
huntstop
port 50/0/7
huntstop
port 50/0/8
huntstop
port 50/0/9
huntstop
port 50/0/10
huntstop
port 50/0/11
huntstop
port 50/0/12
huntstop
port 50/0/13
huntstop
port 50/0/14
huntstop
port 50/0/15
huntstop
port 50/0/16
huntstop
port 50/0/17
huntstop
port 50/0/18
huntstop
port 50/0/19
huntstop
port 50/0/20
huntstop
port 50/0/21
huntstop
port 50/0/22
huntstop
port 50/0/23
huntstop
port 50/0/24
huntstop
port 50/0/25
huntstop
port 50/0/26
huntstop
port 50/0/27
huntstop
port 50/0/28
huntstop
port 50/0/29
huntstop
port 50/0/30
huntstop
port 50/0/31
huntstop
port 50/0/32
huntstop
port 50/0/33
huntstop
port 50/0/34
huntstop
port 50/0/35
huntstop
port 50/0/36
huntstop
port 50/0/37
huntstop
port 50/0/38
huntstop
port 50/0/39
huntstop
port 50/0/40
huntstop
port 50/0/41
huntstop
port 50/0/42
huntstop
port 50/0/43
huntstop
port 50/0/44
huntstop
port 50/0/45
huntstop
port 50/0/46
huntstop
port 50/0/47
huntstop
port 50/0/48
huntstop
port 50/0/49
huntstop
port 50/0/50
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
tag 4 PAGING
tag 5 Call on Hold
tag 6 Select Line
tag 16 Last Name
tag 17 First Name
tag 22 Records 1 to
tag 23 of
tag 25 Wrong PIN
tag 30 Private
tag 33 Exit
tag 34 Update
tag 35 Remove
tag 36 entered
tag 37 left
tag 40 Acct
tag 41 Flash
tag 42 Login
tag 47 Reset Phone
tag 49 Add
tag 50 Change
tag 52 Username
tag 53 Password
tag 54 Logout?
tag 57 Music
tag 59 Mobility
tag 61 On
tag 62 Off
tag 66 Select
tag 67 Enable
tag 68 Disable
tag 72 PIN
tag 73 Delete
tag 74 Make Call To
tag 79 Lable
tag 80 Number
tag 89 Next
tag 90 Previous
tag 91 Whisper
tag 102 Logging Out
tag 109 CME pickup
tag 126 Join
tag 127 Unjoin
tag 130 Join Failed
tag 136 Name
tag 137 Back
tag 138 Submit
tag 141 PickUp
tag 142 Dial
tag 143 EditDial
tag 144 Search
License Supported:
Dear kim Louis,
Could you please explain with more clarity.Because this is the first im doing srst configuration
Dear Amit Sharma,
As per your advise i appiled that fast track commands but still facing same problems that is 7821 and 6921 phones are not getting registered on srst router after cucm down
Note:7940,7962 phones registration successfully on srst router after cucm down
Please find attachment of srst router configuration file
Please Please help me
