Issues with Single number reach
bparker
Hello all, Im having an issues with SNR. I have configured everything in CUCM to send to my cell phone. when a user calls me it rings my cell but when i answer it immediate hangs up the call. Im not sure what the issue could be. has anyone else had this issue before? Im running CUCM 11.5 u6 I have a cube to my sip provider. I have MTP configured and setup on the trunk.
Jaime Valencia
Have you adjusted the answer too soon timer?
What does the debugs from the GW handling the call show?
java
if this helps, please rate
Here is a screenshot of my timers and a debug from cube.  the 7000 is my test number calling the 3047 number which is the internal number and 6493 is the cell number.
So i messed with the timer and set it to 2 seconds to wait. the call comes in and if i answer it right away the call hangs up but if i wait 2 or more rings the call stay connected. I tested this 5 times and same the same result each time. mobility works as well.
