Jabber client cannot login when primary IMP is unavailable
fei he
Level 2
Level 2
We have 2 x IMP 9.1 servers in cluster and Jabber client running.  Current Jabber client work since we use IMP primary IP for login. When primary IMP server becomes unavailable, Jabber client seems cannot login anymore.
How can we fixed this?
Fei
Jaime Valencia
Have you configured your SRV records for this?
java
if this helps, please rate
Jaime
Thx for response but what is SRV? How and where is SRV record configured?
Fei
http://en.wikipedia.org/wiki/SRV_record
The jabber deployment and installation guide has all the details of the SRV records that Jabber uses.
You can also google how to configure SRV records if you need further instructions.
java
Thanks Jaime, I will do some homework.
