Jabber domain issues - same domain but need to go to different cucm
carl_townshend
Hi All
We have an issue, we have a domain configured on the inside, of which the Jabber uds discovery process finds its servers.
The issue is, we have the same domain configured in our overseas sites, and so the uds discovery points them to our cucm cluster, however we need there clients to go to there local cucm server in country.
Is there any way I can get this to work?
cheers
Jaime Valencia
Configure ILS between the two clusters and if the two clusters share the same LDAP source/OUs, make sure the users have the home cluster only checked on one cluster to avoid issues.
java
if this helps, please rate
Can they be local users also?
Is it easy enough to enable to ILS service?
ILS will work with any user, yes, you can refer to the ILS configuration guides, but it's fairly easy.
java
