Jabber dropped audio at beginning of a call for a couple of seconds
drkwbr
Hi guys,
we have trouble with delayed/dropped audio connections from/to Jabber Clients after answering the call.
It takes sometimes 1 sec. up to 3-4 seconds to hear the other party.
The first audio packets are dropped and after this, the audio stream is in sync between the two call parties.
Jabber PRT, Jabber audio dumps, Wireshark packet captures on clients and CUCM logs are showing, that from the audio device the voice stream is not received by Jabber to send RTP packet to the other call party in this first seconds.
Clients are running on Windows 10 and also some on 11.
Drivers are updated and other software is deinstalled or disabled.
Bluetooth headsets, usb headsets or built in mic and speaker from notebooks, it doesn't make a difference.
Clients for testing are connected to the same switch, no WAN link between, no transcoding or MTP source is used.
One software component could cause this problem.
There is Forti-Client used as VPN client and firewall etc..
After installing this software the problem occures and after deinstalling there is no problem.
So it's reported by the customer.
Used Versions:
CUCM 14SU3
Jabber 14.3.1
Forti-Client 7.0.10
Here some findings by Cisco TAC regarding gstreamer audio not fast enough:
2024-02-29 09:00:06,437 WARN [0x00002a1c] [PME(0) ] [pme] [<GStreamer>] - grabber_audio_src [gstbaseaudiosrc.c(911), gst_base_audio_src_create()]-> create DISCONT of 25920 samples at sample 31200
2024-02-29 09:00:06,437 WARN [0x00002a1c] [PME(0) ] [pme] [<GStreamer>] - grabber_audio_src [gstbaseaudiosrc.c(916), gst_base_audio_src_create()]-> warning: Can't record audio fast enough
2024-02-29 09:00:06,437 WARN [0x00002a1c] [PME(0) ] [pme] [<GStreamer>] - grabber_audio_src [gstbaseaudiosrc.c(916), gst_base_audio_src_create()]-> warning: Dropped 25920 samples. This is most likely because downstream can't keep up and is consuming samples too slowly.
2024-02-29 09:00:06,437 DEBUG [0x000007b0] [PME(0) ] [pme] [<PME>] - grabber_audio_src: gst_warning: Can't record audio fast enough (d:\Folder1\workspace\build_windows_vs2015_branch_3.31\source\movi\src\tetris\external\gstreamer\gst-plugins-base\gst-libs\gst\audio\gstbaseaudiosrc.c(916): gst_base_audio_src_create (): /GstPipeline:pipeline0/GstBin:grabber_bin_grabber_audio_main_5/GstDuplexAudioSrc:grabber_audio_src:
Dropped 25920 samples. This is most likely because downstream can't keep up and is consuming samples too slowly.)
And here is some errors with audio driver:
2024-02-29 08:56:33,740 INFO [0x000015a0] [c\accessory\AccessoriesManager.cpp(4229)] [csf.accessory.logi.ucplugin] [logMessage] - [08:56:33.740145] [DisplayController] Handling accessory change: Unknown
2024-02-29 08:56:33,740 ERROR [0x000015a0] [c\accessory\AccessoriesManager.cpp(4249)] [csf.accessory.logi.ucplugin] [logMessage] - [08:56:33.740145] Error: An error occurred while handling the accessory change
2024-02-29 08:56:33,740 INFO [0x000015a0] [c\accessory\AccessoriesManager.cpp(4229)] [csf.accessory.logi.ucplugin] [logMessage] - [08:56:33.740145] [DisplayController] Handling display event: AudioPath
2024-02-29 08:56:33,740 DEBUG [0x000015a0] [c\accessory\AccessoriesManager.cpp(4293)] [csf.accessory.event] [csf::accessory::AccessoriesManager::getFirstControlableCall] - No active device
2024-02-29 08:56:33,740 WARN [0x000015a0] [c\accessory\AccessoriesManager.cpp(3918)] [csf.accessory.api] [csf::accessory::AccessoriesManager::processOnActiveDeviceChanged] - No Connected Call available to check Mute Status
Has anybody hitting a similar problem with delayed and dropped audio at beginning of a call?
What could be the problem with Forti-Client, that it is dropping audio packets?
Customer also opened a ticket on Fortinet side to get support.
KR
Dirk
vijay-k
I have this problem too, still we are unable to conclude this problem. Could you confirm how it's fixed from your infra.
Also, I can see the below error as well for the impacted call. Is it the same observed in your logs?
Line 27083: 2024-03-14 13:31:37,320 WARN [0x00004118] [PME(0) ] [pme] [<Audio>] - [CAPTURE] AudioRingbuffer::Read - returning due to timeout.
Line 30801: 2024-03-14 13:31:38,326 WARN [0x00004118] [PME(0) ] [pme] [<Audio>] - [CAPTURE] AudioRingbuffer::Read - returning due to timeout.
Line 30851: 2024-03-14 13:31:39,346 WARN [0x00004118] [PME(0) ] [pme] [<Audio>] - [CAPTURE] AudioRingbuffer::Read - returning due to timeout.
Line 30940: 2024-03-14 13:31:40,366 WARN [0x00004118] [PME(0) ] [pme] [<Audio>] - [CAPTURE] AudioRingbuffer::Read - returning due to timeout.
Line 30980: 2024-03-14 13:31:41,376 WARN [0x00004118] [PME(0) ] [pme] [<Audio>] - [CAPTURE] AudioRingbuffer::Read - returning due to timeout.
rikardkrvaric
I had an issue where the first 15 seconds (EXACTLY 15 Seconds!) was not heard - no communication back and forth... then suddenly, it worked. Of course, most people will hang up before the 15 seconds are up, thinking something is wrong.
Internal calls worked fine - external calls (in bound or out bound) had this issue.
Turns out, our calls went through Cisco firewall...  it was killing the first 15 seconds of audio.
Do you have a firewall in between?
Is there a difference between Internal Calls & External calls?
Inbound vs Outbound?
Calls internally on same site, vs internally intra-site?
