Jive ITSP SIP trunk between CUBE CUCM
dsobrinho
Level 9
Level 9
Hi team, We have the following scenario : Customer want integrated Jive ITSP Sip Trunk to Collaboration environment. The ITSP have a service based in the cloud but use the Internet access (no Secure). Now the ITSP is reporting that have a security environment with TLS and SRTP Does anybody have already integrated SIP Trunk (Jive) with Unified Communications managers/VoiceGateways or CUBE? Best regards,
Daniel Sobrinho
This is a great document on how to configure tls and srtp for cube and cucm
sip trunk. You can follow the same concept with your ITSP.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-border-element/200104-SIP-TLS-and-SRTP-RTP-internetworking-on.html
Tirtha Tripathy
Check with the documentation of service provider what is required.
Also, cert from service provider needs to be uploaded to cucm servers as callmanager-trust and callmanager.pem certificate from our servers needs to be shared to the remote remote endpoint so that the cucm nodes and Service Provider trust each other.
The document shared is also good.
Tirtha
Regards, Tirtha
