02-04-2013 08:52 AM - edited 03-16-2019 03:31 PM
All,
been working on the UCS since day 1 and have been thrown into a situation with an MCS 7800 series server running CM 6.x that appears to be down. Can't ping it or browse to it. I connected a monitor and USB keyboard to it and got no response. Connected monitor and USB keyboard to other MCS server and get a prompt to log in.
Anyone have any ideas on what to try net to get management level access to this server?
Thanks in advance! replies rated
02-07-2013 07:19 PM
Hi Scott,
The suject says " KVM..." are you trying to switch between these MCS servers via the KVM switch console ?
I would suggest you access these servers via the below Management ports:-
for HP servers - iLO port
for IBM servers - IMM port
Try the below steps for further troubleshooting;-
HTH,
Gifton Abel.
02-07-2013 07:32 PM
Tanks for the response. It turned out to be a bad DIMM. Replced it and we are now up and running.
