las llamadas no entran da tono de ocupado
luisalviarez
El E1 es de CANTV es CAS R2 pero muchas llamadas se pierden solo levantan 8 canales los demás dan tono de ocupado
2173051: Jul 23 08:46:00.620: htsp_process_event: [0/0/1:0(23), R2_Q421_IDLE, E_DSP_SIG_0000]
2173052: Jul 23 08:46:00.620: r2_q421_ic_seize(0/0/1:0(23)) Rx SEIZURE
2173053: Jul 23 08:46:00.620: r2_reg_start_digit_collection(0/0/1:0(23))
2173054: Jul 23 08:46:00.620: r2_q421_ic_seize(0/0/1:0(23)) Tx SEIZE ACK (with 100ms delay)vnm_dsp_set_sig_state:[R2 Q.421 0/0/1:0(23)] set signal state = 0x8vnm_dsp_set_sig_state:[R2 Q.421 0/0/1:0(23)] set signal state = 0xC
2173055: Jul 23 08:46:00.620: htsp_timer - 2000 msec
2173056: Jul 23 08:46:00.620: r2_reg_process_event: [0/0/1:0(23), R2_REG_IDLE, E_R2_REG_START_COLLECTION(94)]
2173057: Jul 23 08:46:00.620: r2_reg_start_collecting(0/0/1:0(23))
2173058: Jul 23 08:46:00.620: r2_reg_timer_stop(0/0/1:0(23))
2173059: Jul 23 08:46:00.624: htsp_process_event: [0/0/1:0(23), R2_Q421_IC_SEIZE, E_HTSP_SETUP_ACK]
2173060: Jul 23 08:46:00.624: r2_q421_ic_setup(0/0/1:0(23)) E_HTSP_SETUP_ACK
2173061: Jul 23 08:46:00.624: htsp_timer_stop
 --More--         2173062: Jul 23 08:46:00.624: r2_reg_offhook(0/0/1:0(23))
2173063: Jul 23 08:46:00.624: r2_reg_process_event: [0/0/1:0(23), R2_REG_COLLECTING, E_R2_REG_OFFHOOK(95)]
2173064: Jul 23 08:46:00.624: r2_reg_ic_offhook(0/0/1:0(23))
2173065: Jul 23 08:46:00.624: R2 Incoming Voice(0/1): DSX (E1 0/0/1:22): STATE: R2_IN_IDLE R2 Got Event R2_START
2173066: Jul 23 08:46:00.796: htsp_dsp_message: SEND_SIG_STATUS: state=0x8 timestamp=33954 systime=25152747
2173067: Jul 23 08:46:00.796: htsp_process_event: [0/0/1:0(23), R2_Q421_IC_WAIT_ANSWER, E_DSP_SIG_1000]
2173068: Jul 23 08:46:00.796: r2_q421_ic_clr_fwd_idle(0/0/1:0(23)) Rx CLEAR FWD
2173069: Jul 23 08:46:00.796: r2_reg_channel_disconnected(0/0/1:0(23))
2173070: Jul 23 08:46:00.800: R2 Incoming Voice(0/1): DSX (E1 0/0/1:22): STATE: R2_IN_PRE_CALLERID R2 Got Event R2_STOP
2173071: Jul 23 08:46:00.800: r2_reg_generate_digits(0/0/1:0(23)): Tx digit '#'
2173072: Jul 23 08:46:00.800: htsp_timer - 2000 msec
2173073: Jul 23 08:46:00.800: htsp_process_event: [0/0/1:0(23), R2_Q421_IC_CLR_FWD, E_HTSP_RELEASE_REQ]
2173074: Jul 23 08:46:00.800: r2_q421_null_release(0/0/1:0(23)) E_HTSP_RELEASE_REQ
2173075: Jul 23 08:46:00.800: r2_reg_process_event: [0/0/1:0(23), R2_REG_COLLECTING, E_R2_REG_DISCONNECT(91)]
2173076: Jul 23 08:46:00.800: r2_reg_disconnect_collect(0/0/1:0(23))
2173077: Jul 23 08:46:00.800: r2_reg_timer_stop(0/0/1:0(23))
Jaime Valencia
Para postear en español te recomiendo la comunidad de dicho idioma, da click en el drop-down de language y ahí la vas a ver, esta comunidad es dedicada al idioma inglés.
java
if this helps, please rate
