LDAP Integration - which user rights are necessary ?
Antonio Brandao
Hi All,
I been working in a integration of CM 8 and MS AD and I would like to know the user to integrate it need to be administrator of AD or not ?
If not which kind of rights are enouth ?
Is there any cisco docs that says about it ?
I been searching about but just found a not in a doc saying
"Note:
Cisco recommends that you create a specific account with permissions in order to allow it to read all user objects within the sub-tree that was specified by the user search base. The sync agreement specifies the full Distinguished Name of that account so that the account can reside anywhere within that domain."
Could you someone clarify that ?
AB
5 Replies 5
Chrysostomos_CY
Level 5
Level 5
Design Considerations for LDAP Authentication
Observe the following design and implementation best-practices when deploying LDAP authentication with Cisco Unified CM:
•Create a specific account within the corporate directory to allow Unified CM to connect and authenticate to it. Cisco recommends that you use an account dedicated to Unified CM, with minimum permissions set to "read" all user objects within the desired search base and with a password set to never expire. The password for this account in the directory must be kept in synchronization with the password configuration of the account in Unified CM. If the account password changes in the directory, be sure to update the account configuration in Unified CM. If LDAP synchronization is also enabled, you can use the same account for both functions.
•Enable LDAP authentication on Unified CM by specifying the credentials of the aforementioned account under LDAP Manager Distinguished Name and LDAP Password, and by specifying the directory subtree where all the users reside under LDAP User Search Base.
•This method provides single logon functionality to all end users: when they log in to the Unified CM User Options page, they can now use their corporate directory credentials.
•Manage end-user passwords from within the corporate directory interface. Note that the password field is no longer displayed in the Unified CM Administration pages when authentication is enabled.
•Manage end-user PINs from the Unified CM Administration web pages or from the Unified CM User Options page.
•Manage Application User passwords from the Unified CM Administration web pages. Remember that these application users facilitate communication and remote call control with other Cisco Unified Communications applications and are not associated with real people.
•Enable single logon for Unified CM administrators by adding their corresponding end user to the Unified CM Super Users user group from the Unified CM Administration web pages. Multiple levels of administrator rights can be defined by creating customized user groups and roles.
From the SRND
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/directry.html#wp1070369
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
David Hailey
The simple translation is that Cisco is recommending that you have a service account created and used for the CUCM DirSync integration with LDAP.  That account only needs Read Only permissions to the OU or OU(s) in AD where the end user accounts are located.
Hailey
Please rate helpful posts!
Antonio Brandao
At least say one thank you
chrysostomos
Hey Chrysostomos
Sorry I was away, Thanks a lot for you explanation was very helpful
I did a test with normal domain user which I created and it worked fine, so it´s necessary to be admin rights user to integrate the CM and MS AD
Hi Antonio
You mean its not necessary to have admin rights the user account in LDAP
chrysostomos
