LDAP Sync with multiple OU.
odinhuodin
Hi all,
Its possible insert multiple OU in LDAP User Search Base(LDAP Authentication)?
Or the only way is insert one root with contains OU's ??
CCM ver: System version: 5.1.3.5000-3
Administration version: 1.1.0.0-1
Thx
Jaime Valencia
you can configure 5 user search bases
for authentication it's only 1 ou that should be the parent of all the users that will require it
java
if this helps, please rate
java
Jaime Valencia
java
java
Humm, OK Thanks javalenc !!
