Showing results forĀ
Search instead forĀ
Did you mean:Ā
Licensing help on MCS7816 CUCM Server
lifeoverip
how many maximum phones can I have  registered to a single MCS7816 CUCM appliance? what is the cisco recommendation
Also can i have more then the recommended licenses or if you reach a limit the CUCM will refuse to intall licenses above the recommended limit
How can i check the CUWL license utilization on the actual CUCM server?
Reason i ask is that i have purchased 100 cuwl licenses for two 7816 servers (pub + sub). But when i look at the licence unit report on CUCM its showing 2400 units authorized under the phone licence feature menu. Not sure what a 'unit' means or if that is the same a license.
any help will be appreciated
Chris Deren
500 users per server:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/callpros.html#wp1043871
There is nonhard limit set, so you will be able to add more with the risk of over subscribing and causing performance issues.
DLUs are units as different types of phones use different number of units, most typical hard phones use 4 units each, you can see a calc under the licensing section.
HTH, please rate all useful posts!
Chris
