06-15-2007 05:50 AM - edited 03-14-2019 10:05 PM
Hi, is there a method (log file) to tell when a certain change was made to a Call forward on a phone within Callmanger 5.1. Firstly I am after looking at when config changes were made and secondly (if possible) by which MLA account.
Thanks in advance!
Regards Mark
06-18-2007 03:44 PM
all the log files are under program files\cisco\trace\ccm. You may need to contact Cisco so they can read it for you though.
06-19-2007 01:39 AM
Are you aware whether there any specific logs that ref the admin page changes made?
06-19-2007 03:20 PM
I am not aware of these, but there are many logs you can turn on. There are some enabled by default and others are not. Do you know where to check?
in CCM > Application > Cisco CallManager Serviceability
In Cisco Callmanager Serviceability > Trace > Configuration > pick the server or servers from the list on the left pane > click the type of info you want. I picked Cisco Call Manager > and then you can select what Trace you want.
06-19-2007 10:49 PM
Thanks for your reply, yes I was aware of these logs, but not that they contained details of CM config changes.So now I am after the methods of how to extract this information from these logs.
Kind Regards Mark
