Loopback dial-peer
sachin.hello
Hi Guys,
Please explain the "Loopback Dial-peer" with any example.
Sachin
Chris Deren
What is the question in regards to? Where is this coming from?
It probably pertains to binding a dial-peer to the loopback interface on the gateway via either bind command or routing locally, i.e. CME via session target pointing to the loopback interface.
HTH,
Chris
Hello Chris,
It is something related to matching a same dial-peer for inbound and outbound call legs, on the same  router.
Could you throw more light on it.
Sachin
