Lost of voice packets when voice and data traffic sent in the same time.
melitrissa2007
I am working on QoS implementation in our network.
I created the test scheme which consists of two switches (Cisco 3560/ Cisco 2960) and four laptops.
My QoS settings the following:
- mark voice traffic in dscp ef
- mark signal traffic in dscp af31
- mark video traffic in dscp af41
- create two egress queues: one for traffic with dscp ef, a31, af41 and second for other traffic. First queue is priority.
- create policy-map QOS_POLICY for marking traffic and
congestion management.
So, the following QoS setting were applied on two switches:
mls qos map policed-dscp  34 46 to 0
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 2 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 2 0 1 2 6 7
mls qos srr-queue output dscp-map queue 1 threshold 2 24 26 32 34 46
mls qos srr-queue output dscp-map queue 2 threshold 2 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 2 threshold 2 8 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 2 threshold 2 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 2 25 27 28 29 30 31 33 35
mls qos srr-queue output dscp-map queue 2 threshold 2 36 37 38 39 40 41 42 43
mls qos srr-queue output dscp-map queue 2 threshold 2 44 45 47 48 49 50 51 52
mls qos srr-queue output dscp-map queue 2 threshold 2 53 54 55 56 57 58 59 60
mls qos srr-queue output dscp-map queue 2 threshold 2 61 62 63
mls qos queue-set output 2 threshold 1 100 50 100 200
mls qos queue-set output 2 threshold 2 100 100 100 400
mls qos queue-set output 2 buffers 5 95 0 0
mls qos
class-map match-all SIGNAL_CLASS
 match access-group name SIGNAL
class-map match-all VIDEO_CLASS
 match access-group name VIDEO
class-map match-all VOICE_CLASS
 match access-group name VOICE
 class VOICE_CLASS
  set dscp ef
  police 5000000 8000 exceed-action policed-dscp-transmit
 class SIGNAL_CLASS
  set dscp af31
  police 256000 8000 exceed-action drop
 class VIDEO_CLASS
  set dscp af41
  police 10000000 8000 exceed-action policed-dscp-transmit
 class class-default
  set ip dscp default
Extended IP access list SIGNAL
     permit tcp any any range 11000 11999
   permit tcp any any range 2000 2002
     permit udp any any range 29120 29131
     permit tcp any any range 5060 5061
     permit udp any any range 5060 5061
     permit udp any any range 1718 1719
       permit tcp any any eq 1720
     permit tcp any any eq 2428
     permit udp any any eq 2427
    permit ip any any dscp af31
Extended IP access list VIDEO
     permit udp any any eq 2326 2485
     permit tcp any any eq 5555 5574
     permit ip any any dscp af41
Extended IP access list VOICE
     permit udp any any range 29100 29119
      permit udp any any range 16384 32767
     permit ip any any dscp ef
interface FastEthernet0/1
 description Trunk to switch2
 switchport mode trunk
 srr-queue bandwidth share 1 100 1 1
 queue-set 2
 priority-queue out
 mls qos trust dscp
interface FastEthernet0/2
description Data traffic
 switchport access vlan 20
 queue-set 2
 priority-queue out
 mls qos trust dscp
 spanning-tree portfast
 service-policy input QOS_POLICY
interface FastEthernet0/3
description Voice traffic
 switchport access vlan 10
 queue-set 2
 priority-queue out
 mls qos cos 5
 mls qos trust dscp
As I see in results of command -  show mls qos int stat, the traffic is marked and added to egress queue correctly.
But when I start iperf   I see 25% lost packets for voice traffic and 5% for data traffic when data and voice  are sent in the same time.
For test I use the following settings in iperf:
1. For voice traffic
- server - iperf.exe -s -u -i 5
- client - iperf.exe -c  host 192.168.1.2 -u -i 5 -t 100 -b 5m
2. For data traffic
- client - iperf.exe -c  host 192.168.2.2 -u -i 5 -t 100 -b 100m
But I notice, if I remove the command mls qos map policed-dscp  34 46 to 0 from  two switches  I don't get  lost packets on when I start iperf.
I think, maybe it  doesn't work on l2.
Could you help me understand it?
What I do  wrong?
Thank you in advance
0 Replies 0
