Showing results forĀ
Search instead forĀ
Did you mean:Ā
Low disk Space on CUCM 6.1
ayoussef.kamal
Hi  Experts,
I have a lot of critical alarms on Real Time Monitoring Tool on my CUCM 6.1. I attached the error. I have the following questions:
1- what is the criticality of this error?
2- How/where i can reconfigure the low/max thresholds of disk space usage?
3- what is the impact if i reconfigure those thresholds.
BR,
rafamartini
Hi Kamal,
This alarm indicates that you disk i getting full.
This is the first alarm that youĀ“re going to receive, if you donĀ“t take no actions you will start to receive "HighWater" alarms, when receiving this, the system will start to delete files on Log Partition, to avoid disk be complete full.
Check the trace/logs configuration on Cisco Unfied Serviceability, there you can control the number o trace files and size that server can store. Also perform a clean up on disk for unused trace/log files using RTMT.
Detailed information:
http://cisco.sitecelerate.com/en/US/docs/voice_ip_comm/cucm/managed_services/cucm_health.html
