Maniupulating Called Number from Devicepool
DenysAdams
Hi All,
Submitting to the collective wisdom, i need to be able to specify a device pool of phones to have any number dialed from this device pool to append a digit to numbers called.
EG phone 1 in device pool DP_Test
1#dials 19710
2#dials 035564261
device pool config makes it (with the digit 1 appended) specifically for this device pool and ALL numbers dialed
1#dial  119710
2#dial  1035564261
Can anyone point me in the right directions.
If only CLID is a concern then this approach should work fine and i believe one device pool can be used however create two separate CSS 's.
Phone 1- 434XX- CSS1- Allow partition 1 with route pattern 1( with prefix 0) this will match dial-peer 4
Phone 2-435XX- CSS2- Allow partition  2 with route pattern 2 ( with prefix 01)- will match dial-peer 7.
Or second option would be to create dial-peer based on ANI.
Answer address 434XX for phone 1 and then restrict or allow the CLID .
5 Replies 5
Jaime Valencia
Exactly what you want to change, just how the called number is presented??
Or effectively change 19710 into 034464261 as a TP??
Also, is all that just internal, or external numbers??
java
if this helps, please rate
to shed a bit more light on the situation
i have 2 dial peers on my Vrouter
currently calls go out via one dialpeer
i want phones within a device pool to append a digit 1 for example so they use the next dial peer
so not how the call is presented the dialed number out.
and just to external numbers
eg phone 1 in DP_TEST dials 555555,
it hits the Vrouter as 1555555.
They only way I could think of doing this, would be using LRG, and doing the digit manipulation within each RG as necessary.
java
the two dial peers exist on a single Vrouter.
so i cant do digit manipulation on the gateway.
Thanks for your assistance thus far Jaime
Maybe i should open up the issue further to see if anyone can assist
I have a 200DID Range Exiting on a single Vrouter
I have reception phones in 434XX
And General Phones in 435XX
Currently setup the Vrouter is Tagged to restrict Caller ID
so on outbound calls when a user picks up they see Private Number
Requirements have changed however
we now require that phones from 434XX display 43400
and phones from 435XX display with Private Number
the way i thought to go about this would be two dial peers, using a prefix on the destination pattern to separate them. and have 435XX in 1 device pool and 434XX in a 2nd device pool and user either CSS ro translations to achieve appending a digit on called numbers. However this doesn't look feasible based upon feedback.
Does anyone else have any suggestions as to how to go about this, keep in mind i cannot simply mask the number It has to be flagged clid restrict to get private number.
if i do not flag the number the telco will apply the first range to it automatically.
Hope this is enough info
dial-peer voice 4 pots
preference 3
destination-pattern 0T
incoming called-number .
fax rate disable
clid restrict
direct-inward-dial
dial-peer voice 7 pots
description block caller id
destination-pattern 10T
fax rate disable
clid network-number xxxxx43400
direct-inward-dial
port 0/2/0:15
