IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5538 Views
  • 14 replies
Dear all, I want to configure a phone button on a Cisco IP phone in a CUCM environment, so the user does not have to dial the extension before the international number. Normally a user would dial 910044xxxxxx to place an external call, but if he doe...
Hi, Can you help in doing this. I have CUCM version:11 and I have cisco router 800 series on HQ and 1700 on the remote side. can I have configuration example required for the branch office to register on the Call Manger at HQ. and if I have land line...
Dear All : Thank you for your support  currently i have Call manager 6.1.2 in cluster (Publisher-Subscriber mode) , for sorry a hardware problem happens to the motherboard of the publisher  Platform Type7816H3 since the license on this version is ...
Hi , I just got a problem with call history time and date , it took more than 4 second to show me the time and date for any call , for instance if I selected missed call from the Directory button , missed call time and date take more than 4 seconds t...
On 5/2/16 a lightning strike destroyed our existing modem incorporating VOIP. We replaced the modem with a D-Link DSL-2880AL modem router that did not have VOIP.   So we purchased a Linksys PAP2T-NA analogue telephone adaptor (ATA) and connected our ...
mcibud001 by Level 1
  • 515 Views
  • 0 replies
Disk/active         20304764K        7399656K       12698824K (64%)Disk/inactive       20304764K        7562028K       12536452K (63%)Disk/logging        70646184K        2077832K       64979696K (97% admin:show diskusage common sortThis command can...
Aman . by Level 1
  • 9205 Views
  • 9 replies
Using PCD, when try to migrate it give us the following errror "unable to power on the VM named ". The OLD CUCM is 8.0 in MCS Server. The PCD is installed in ESXi 6 The New CUCM OVF is installed in ESXi 5.5, please let me know the workaround for the...
