Match inbound dial-peer with multiple user-ids
krcoe
Long time reader, first time poster. Be gentle.
I am running into an issue with inbound dial-peer matching in our multi-tenant config on our CSR1000v.
I originally started with matching by host IP address, but if i have 2 separate customers that are residing on the same PBX server sending calls to the UBE, the peer-matching is a bit spotty and calls are misrouted.
I tried to change the configuration to match by the number being called (user-id), but soon discovered the UBE will only let me put in 1 user-id per uri entry which will not work in the long term as some of our customers have 1,000+ phone numbers.
Am I missing something? Do i need to try a different approach?
0 Replies 0
