06-25-2012 06:15 AM - edited 03-16-2019 11:50 AM
Hello
i want to activate the link aggregation on my MCS 7800 Series (Callmanager Enterprise - at the moment I only use ETH0)
So does anyone know who to activate this feature? Or have any how-know for this feature.
I do not find anything about the feature
Solved! Go to Solution.
06-25-2012 06:25 AM
The 2nd NIC on the MCS servers can only be used as a backup for ETH0, there's no other way to use it for any other purpose.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
06-25-2012 06:25 AM
java
06-25-2012 06:29 AM
thanks, for your fast reply.
