09-15-2010 11:40 PM - edited 03-16-2019 12:48 AM
Dear all,
When we scheduled meeting in meeting place through web link it is not sending automated emails to invitees.
Can some one please help me in this.
Thanks in advance.
AteeQ
Solved! Go to Solution.
09-20-2010 11:24 PM
go into meetingtime, and under one of the tabs there is a "notification queue"
open that up after you schedule the meeting and see if it is hung.. you may want to purge them out if there are many building up.
there is a service on the web server that you can try restarting also.. its the notification gateway. it wont hurt to restart that service because you arent gettiing notifications anyway... there is a service account tied to that service as well, make sure those logins are still valid.
09-20-2010 11:24 PM
09-21-2010 05:31 PM
Hurrrrrrrrrrrreeeeeee
Thanks for your reply,
I have resterted notification gateway and it is started working.
Thanks.
AteeQ
09-22-2010 05:22 AM
Check your /opt directory, its probably full. Delete files that you dont need out of there like upgrades, patches, etc. You will most likely notice that the /opt directory is about 99 percent full or close to it. When that happens emails will no longer be sent but will show as queued. There is a thread on this same topic if you do a search. Good luck.
Edit, didnt see the other reply. Glad its working!
